Fluid leaking form the pit arm.
Old Jun 24, 2009 | 12:25 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Default Fluid leaking form the pit arm.
So I have a leak coming from the pit arm. Well front the power steering pump? What Should I do to fix it or stop the leak? I would says its on the fast side for a leak.
Old Jun 24, 2009 | 12:40 PM
Cereal Killer's Avatar
Cereal Killer
Replace the power steering pump
Old Jun 24, 2009 | 12:55 PM
dodge15004x45.9
Whatever is above the pit arm is leaking. I guess its time for a trip to napa and pep boys to get a haynes book.
Old Jun 24, 2009 | 04:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is nothing above the pitman arm except the gear box and the 2 hoses, and quite possibly a PS pump cooler. Either one of the hoses is leaking, which is possible but unlikely or the seal for the pitman arm shaft(stub shaft) is leaking. Clean the whole thing off and find where it's leaking. And IIRC , there is a DIY on replacing the seal .
Old Jun 24, 2009 | 07:21 PM
dodge15004x45.9
What every the pit arm going into is leaking. Not sure about the DIY I'll check it out,
Old Jun 24, 2009 | 07:41 PM
dodge15004x45.9
DO you mean this?
https://dodgeforum.com/forum/2nd-gen...p-rebuild.html
Old Jun 24, 2009 | 08:31 PM
dhvaughan's Avatar
dhvaughan
no, that's a ps pump rebuild, and its a long way from the pitman arm. he's probably got a leaking steering box.
see this. http://www.pavementsucks.com/tech/steeringbox.php
Old Jun 24, 2009 | 09:36 PM
bigblockmopar419's Avatar
bigblockmopar419
its the steering box that is leaking around where the stub shaft is. around the shaft there is a seal that blows after time because our steering shaft is not strong enough so it wobbles causing the seal to wear a groove in the then over time the seal starts to leak and then finally falling out!! i had the same thing happen in my 2500 v10 4x4 its better to replace the whole box mine was 230 bucks out the door at advance i think but i belive there is a 30 dollar core charge! if u have bigger than stock tires it puts alot more stress on the stub shaft! so if u do u might want to get the steering support bar from bd diesel has them i know!!
Old Jun 24, 2009 | 09:41 PM
dodge15004x45.9
Yep Thats what it is. My steering box is leaking. I'll get a pick up when its light out.
Old Jun 25, 2009 | 08:02 AM
dodge15004x45.9
Heres the pick.
