Hub nut socket
Old Jun 26, 2009 | 04:59 PM
rmiller's Avatar
rmiller
Default Hub nut socket
I'm replacing front hub bearings on my 95 Ram 1500 4x4. Only problem is I can't find the right socket to remove the hub (spindle) nut. I believe it's a 1 3/4" nut but my 1 3/4" socket won't work because its' outside diameter is to large to fit into the recess that houses the nut.
Looks like I need a thin walled socket. Or maybe it's a special tool? I spent a big part of the day searching the parts stores with no success. The replacement bearing has a wider recess so there's no problem installing the new one. I just can't get the old one off.
If anyone has had this problem could you please tell me what socket I need and where might I buy it. Thanks
Old Jun 26, 2009 | 05:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's 1 11/16's
Old Jun 26, 2009 | 06:00 PM
Sheriff420's Avatar
Sheriff420
tractor supply will have that socket and i think harbor freight or sears may also. i've heard that 1 11/16ths is not a common size. it took me a while to find too, most places go up to 1 1/4 socket for the biggest one available.
Old Jun 26, 2009 | 06:13 PM
zman17's Avatar
zman17
Sears also if you have one close by.
Old Jun 26, 2009 | 07:12 PM
Rebhays27's Avatar
Rebhays27
If you don't plan on using it very soon Autozone and O'Reiley's have them to loan on their loan a tool program.
Old Jun 26, 2009 | 07:16 PM
99Silver1500's Avatar
99Silver1500
TSC's are a 1 inch drive, and only $7. I am doing the same thing, got the niut, but cant find my 1" drive GRRR.
Old Jun 26, 2009 | 07:22 PM
Magnumpwr16's Avatar
Magnumpwr16
yeah its 1 11/16 i just did my hubs and its not gonna be easy to get off. Not a common size, Sears had it for me. It's torqued to 175ft/lb.s' have fun lol
Old Jun 26, 2009 | 07:31 PM
Sheriff420's Avatar
Sheriff420
tractor supply had mine in 3/4" drive for 6 and some change and a 3/4" breaker bar for 15$. if you have trouble getting it to break loose, i was reading on an antique tractor forum that a 50/50 mix of atf and acetone is the best penetrant around. they did a torque test on a bunch of penetrating fluids and it took half the torque to break with the atf mix over kroil oil. and 1/4 the torque compared to pb blaster.
Old Jun 26, 2009 | 07:43 PM
zman17's Avatar
zman17
My socket is also 3/4 drive, but I also have an adapter to reduce it to 1/2".
Old Jun 27, 2009 | 01:28 AM
dhvaughan's Avatar
dhvaughan
neither my autozone nor advance had that size. i had to get it from the EXPENSIVE parts store for $25, it was 3/4 drive.
