Rear axle fill plug question
Old Jun 27, 2009 | 12:55 PM
priest1981's Avatar
priest1981
Default Rear axle fill plug question
Has anyone seen a thread in fill plug replacement for the junk rubber plugs that Dodge put in our trucks?
Thanks,
Will
Old Jun 27, 2009 | 01:28 PM
aim4squirrels's Avatar
aim4squirrels
Nope, you don't really need one as the gear oil shouldn't be filled over the lip of the fill plug anyhow. If your plug's bad try grabbing one from a junk yard or call the dealer or try LMC truck and see if they stock it.
Old Jun 27, 2009 | 10:24 PM
priest1981's Avatar
priest1981
Has a new plug and it leaked from the day it was put in. You know I just thought, I bet my vent is plugged. I park on a sloped driveway and it always leaks, on the slope the fluid is over the lip.
Thanks,
Will
Old Jun 27, 2009 | 10:31 PM
dhvaughan's Avatar
dhvaughan
sounds like its the wrong rubber plug.
i'd try another one, from the dealer. it couldn't cost more than $2-3.
if you really want a screw in plug, remove the cover and weld in a nut on the back.
Old Jun 28, 2009 | 11:45 PM
priest1981's Avatar
priest1981
I'll try that also, I think the one that's in it is from Car Quest.
Thanks,
Will
