Air conditioning issues
Old Jun 27, 2009 | 02:57 PM
azffighter's Avatar
azffighter
Default Air conditioning issues
Hi, I have a 96 dodge ram with some A/C problems and the person working on it is wondering if I have a picalo tube or a expansion valve. I have plenty of freon in the system but I'm still getting warmer air. The Temp will not go below 90 degrees. Any help on this would be greatly appreciated as I live here in Arizona and it's a 110 degrees outside. lol Thanks again.
Ken Heyd
Old Jun 27, 2009 | 05:37 PM
Ram15002ndGen's Avatar
Ram15002ndGen
As far as I know we have an expansion valve. Shouldn't the A/C tech already know that? Why is he asking you? To start off with he should have hooked up gauges to both high & low and checked your pressure on both sides. That alone would tell him if you have enough freon or if there is a blockage. If this person doesn't have any real answers for you, I would find another shop, pronto! He could possibly make a simple problem worse (and you will be stuck with the bill).
Old Jun 28, 2009 | 01:47 PM
azffighter's Avatar
azffighter
Default a/c
He actually works on aircraft and wasn't completely familiar with the dodge, but he does have the gauges hooked up and said I have plenty of freon. He was thinking the expansion valve was possibly stuck open and so I was getting hot air mixed with the cold.
Ken
Old Jun 28, 2009 | 02:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is the compressor cycling on and off? Or does it keep running and you still have warm air?
Old Jun 28, 2009 | 05:33 PM
azffighter's Avatar
azffighter
I think it stays running with the warm air.
Old Jul 24, 2009 | 05:26 AM
azffighter's Avatar
azffighter
So is it difficult to get to the valve? Do I need to go through the engine compartment or under the dash?
Old Jul 24, 2009 | 09:18 AM
charlie1935's Avatar
charlie1935
You don't have an expansion valve, it has the whatchamacallit tube.
Old Jul 24, 2009 | 10:22 AM
zman17's Avatar
zman17
Orifice tube. Which can be replaced on it's own, without having to purchase the whole line like on later models.
Old Jul 24, 2009 | 12:50 PM
charlie1935
That's the word! Thanks zman.
Old Aug 22, 2009 | 06:07 PM
azffighter's Avatar
azffighter
Smile re: orifice tube.
So is it difficult to replace the Orifice tube? Can that be purchased at the auto repair store?
Thanks for the help!
Ken
