New tranny now truck misses at steady throttle?????
Old Jun 28, 2009 | 04:05 PM
aoneill's Avatar
aoneill
Default New tranny now truck misses at steady throttle?????
Just had the tranny rebuilt by a friend of mine who does good work, works/shifts awesome.. now the truck is missing and sometimes running bad..lacking power as well. Replaced the crank sensor and a little better but not yet fixed.. Have had thebefore cat front o2 sensor code for a while, could this make the truck miss.. Runs fine when you hammer it..
thanks for all the help
Old Jun 28, 2009 | 04:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The o2 sensor can cause that, but since we don't even know what year your ride is, I'll go with plenum gasket, and probably cat being no good.
Old Jun 28, 2009 | 04:51 PM
zman17's Avatar
zman17
And btw, is it missing or is the rpm jumping up and down?
Old Jun 28, 2009 | 05:16 PM
jasonw's Avatar
jasonw
Site Moderator
It could be the O2 sensor.
When the computer goes into open loop mode (during warm-up and when you hammer the pedal), it ignores the O2 sensor(s). When its in closed loop mode, it "listens" to the pre-cat O2 sensor(s), and adjusts the air/fuel mixture accordingly. If the sensor is bad, or giving false info, the computer will be improperly adjusting the mixture, which may cause a misfire.
But like zman said, a little more info would help us out. Maybe even create a signature with all of it in there.
Old Jun 28, 2009 | 07:40 PM
aoneill's Avatar
aoneill
Ya i'm an idiot...Its a 97 Ram SLT 5.2 4x4.. Sorry bout that.. I'll replace the o2 sensor and see what happens.. I'll get back.
thanks
Old Jun 28, 2009 | 07:42 PM
aoneill's Avatar
aoneill
nTruck is defenatly missing..no power, backfire through exaust the whole 9 yards, when you tramp on it, seems to work ok..still seems like not much power though.
Old Jun 28, 2009 | 09:03 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Anything will run better when you hammer the gas. Gotta give more specific details so we can help you.
Old Jun 28, 2009 | 09:09 PM
aoneill's Avatar
aoneill
basically truck runs perfect at warm up, usually half way to town temp guage is about 1/4 way up and it will act up, missfire/backfire, if i gas it it clears(open loop) I replaced the crank sensor thinking it was that and the truck ran a bit better but still gets the symptom..Funny thing is is that i have had the p0132 code for some time now with no obvious problems, as soon as i get the truck back from the tranny guy, things are acting up..Anyway i should have the cat checked to see if its not plugged and replace the front o2 sensor..
thanks, i'll let you know
thanks
Old Jul 2, 2009 | 09:19 AM
aoneill's Avatar
aoneill
For all its worth...installed a new forward cat bosch o2 sensor and seems like all problems went away, can't believe it madew that much difference..any happy once again..
thanks all
Andy
Old Jul 2, 2009 | 10:29 AM
gobbell1's Avatar
gobbell1
1.. "if I gas it, it clears" - not a cat problem. A bad(clogged) cat would not allow you to punch it.
2. "ran fine until I got it back from tranny guy" - check the 02 sensors and wires. they have to come out to remove the tranny
