leveling kit
Old Jun 29, 2009 | 06:02 PM
gary30mazak's Avatar
gary30mazak
Default leveling kit
I want to add a 5" lift to my 1998 dodge ram 2500 360 quad cab. I seen a skyjacker kit someplace that will add 5" to the front and 5" to the rear. My main question is do I need to level out the front end 2" first so it will sit level with the kit on? Also where can I get the cheapest leveling kit and how hard is it to install? I want to run 35X 12.50 tires on it after the lift is installed. Thanks guys.
Old Jun 29, 2009 | 06:10 PM
Miami_Son's Avatar
Miami_Son
You might do a search. There's at least several threads on leveling and lift kits already ongoing.
Old Jun 29, 2009 | 06:14 PM
gary30mazak
Miami, I remember you saying you got a good deal on your leveling kit. Where did you get it from?
Old Jun 29, 2009 | 08:48 PM
Miami_Son's Avatar
Miami_Son
Hell Bent via eBay. $65 delivered. Very well built and they have kits up to 3". The 2" kit was perfect for my truck.
Old Jun 29, 2009 | 11:20 PM
olyelr's Avatar
olyelr
You wont need a leveling kit. If you get a 5" Skyjacker kit, it will lift the truck 5" in the front and only 3-4" in the back to level it out. The cheaper ones will come with a block/add-a-leaf, while the more expensive ones will come with new leafs.
35's and 5" is a good combo, but plan on re-gearing.
