What should i replace while front end is apart?
Old Jun 30, 2009 | 11:05 AM
Beachbum3478's Avatar
Beachbum3478
Default What should i replace while front end is apart?
my friend gave me some metal 2" leveling spacers for my 95 ram 1500 2wd 5.2 w/ 149k miles. and im curious while i have the front end kind of apart what i should replace or check out. im already replacing the shocks but what else? also, do the metal coil spacers go below or on top of the coil springs?
Old Jun 30, 2009 | 11:20 AM
Steel Horse's Avatar
Steel Horse
Top!!!
Old Jun 30, 2009 | 12:03 PM
dodgeram07's Avatar
dodgeram07
check the ball joints and tie rod ends.. and re pack the wheel bearing if your looking for some thing to do
and maybe sum before and after pics
Old Jun 30, 2009 | 04:11 PM
gobbell1's Avatar
gobbell1
Perfect timing! I just added the Daystar 1.5" spacer to my 96 2WD. While I had everything apart, I replaced the following:
- Rotors (brake pads were new)
- Wheel bearings
- Ball joints
- Shocks
Other items I should have replaced while everything was torn down...
- lower control arm bushings
- outer tie rods
- sway bar bushings
Old Jun 30, 2009 | 04:24 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Idle arm and pitman arm.
Old Jun 30, 2009 | 04:51 PM
gobbell1's Avatar
gobbell1
- Wheel bearings
- Ball joints
- Shocks
- outer tie rods
- sway bar bushings
