Opinion on Steelies
Old Jul 1, 2009 | 02:46 PM
dakotas ram's Avatar
dakotas ram
northwest arkansas........
2 bad a/ts and 2 decent goetrac radial xlts
Old Jul 1, 2009 | 03:19 PM
audiomechanic's Avatar
audiomechanic
Too far. Drat.
Lol. Thanks anyway though!
Are the standard steelies (not the spare tire rim) as strong as the alluminums?
What's the largest tire I can confidently run on the stock rim (by confidently, I mean, not so huge that the side wall is bulging over the edge of the rim)?
Old Jul 1, 2009 | 07:17 PM
audiomechanic
Here's the truck:
And in this shot, you can see the tilting front wheels and the backspacing on the wheels:
The wheels are not tilted much, but they're tilted enough to cause this on the tires (notice the uneven inner tread = cupping):
I've never liked how far the wheels are pushed out but kept them cause I'm po and planned on eventually adding sick looking fender flares to widen the body over the tires. Fender flare are expensive so it's likely they will not happen in the foreseeable future
Old Jul 1, 2009 | 08:01 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Dude, your truck looks good the way you have it. I wouldn't go the steelie route. Makes you truck look like a base model or a work truck. Why don't you keep your rims and just go down a size or two and see what difference that makes. That should reduce the stress on your system. Go to a local tire place that sells used tires and for like $20 each you can get new (used) tires and give it a try for a while. It can't cost more than changing rims.
Dude, I just looked at your last pic and noticed you have Gooyears. That is your problem right there! I have never liked Goodyear. My truck came with Goodyears and they were horrible. Could never keep it aligned. It was aligned like 20 times and failed each time (kept wearing unevenly and pulling). Finally I replaced them at 20K and got Michellins, what a difference they made. The ride was better, the handling was better and I was able to get an alignment with no trouble at all. You tires are your problem, not your rims!
Old Jul 1, 2009 | 08:21 PM
Miami_Son's Avatar
Miami_Son
I have a hard time believing your wear problems are related to how far the wheels stick out from the fenders. Here's mine:
These wheels have been on my truck for more than 75k miles with no ill effects on anything.
Old Jul 1, 2009 | 09:22 PM
olyelr's Avatar
olyelr
I agree with Miami Son, your wear problem is not necessarily caused by the wheels. And by that pic, I doesn't look like much of a wear problem anyway. Maybe check your alignment out?
I have ran 15x12's on my truck for probably 80k miles of the 160k on the truck (dont use in the winter) and have never had a single wear problem. But yes, they do wear out ball joints and wheel bearings much faster.
And looking at those pics, you only have a 10" wide wheel. A 12" wide wheel will balloon a 12.5" wide tire out much more than those are... trust me, I ran that setup on several sets of tires.
This is a 12" wide wheel...
Old Jul 1, 2009 | 09:23 PM
Lowridetractor's Avatar
Lowridetractor
wow it is too bad you live in Texas i would trade you for my stock wheels and some cash. your truck is nice as is bud.
Old Jul 1, 2009 | 10:20 PM
PurplDodge's Avatar
PurplDodge
I dont know where you get the idea that they are GoodYears, but from the sidewall it looks to say that the tires are Buckshot Maxxis Mudders.
Old Jul 1, 2009 | 10:36 PM
Miami_Son's Avatar
Miami_Son
I'm pretty sure they are B.F. Goodrich Mud Terrains.
Old Jul 1, 2009 | 10:39 PM
PurplDodge's Avatar
PurplDodge
They look nothing like them?
