1995 Ram 1500 5.9L Compatible with this 1996 Transmission?
Old Jul 1, 2009 | 07:40 PM
Mhunter's Avatar
Mhunter
Default 1995 Ram 1500 5.9L Compatible with this 1996 Transmission?
My 1995 Dodge Ram 1500 with 218K miles finally failed me, it has begun to slip and not shift properly all the time. I pulled the transmission out this weekend to replace it with a known good transmission (the image in front is my old transmission and the rear is the intended replacement). I noticed that the topside connections were different; the original is a 3-pin and the replacement is an 8-pin. Do I have any other options other than rebuilding mine or purchasing another tranny? Thanks in advance for your thoughts.
Attached Thumbnails 1995 Ram 1500 5.9L Compatible with this 1996 Transmission?-dscn1102.jpg   1995 Ram 1500 5.9L Compatible with this 1996 Transmission?-dscn1103.jpg   1995 Ram 1500 5.9L Compatible with this 1996 Transmission?-dscn1104.jpg
Old Jul 1, 2009 | 07:46 PM
dodgeram07's Avatar
dodgeram07
the 95 has a 46rh and the 96 has a re
Old Jul 1, 2009 | 10:11 PM
jasonw's Avatar
jasonw
Site Moderator
I originally thought the 1996 had a RE as well, however, other links I've seen report the RE wasn't used until 1998.
Either way, though, going from one model year tranny to another is going to involve a custom wiring job, as most harnesses are different (even from different model years of the 46RE).
Old Jul 1, 2009 | 10:39 PM
Trey318's Avatar
Trey318
That sucks.
Old Jul 1, 2009 | 11:34 PM
wjxavier's Avatar
wjxavier
yea, i think the 96's still had rh's. but like jason said...from year to year, things are going to be slightly different lol
Old Jul 2, 2009 | 12:58 PM
MonteC's Avatar
MonteC
96-02 = 46RE
88?-95=46RH
You can not put a 46RE in the place of a 46RH.
Old Jul 2, 2009 | 04:43 PM
wjxavier's Avatar
wjxavier
i stand corrected...what would we do without you? lmao
Old Jul 2, 2009 | 07:12 PM
Mhunter's Avatar
Mhunter
Thanks to all that replied, I have new direction now - taking it to a shop for rebuild.
