Check engine light code P302
Old Jul 9, 2009 | 05:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So have you checked the plenum and cat ?
Old Jul 11, 2009 | 12:40 PM
97r/tram's Avatar
97r/tram
How would I go about checking the plenum and cat?
Also, after another 100 miles on the new plug, the cel came back on again.
Old Jul 11, 2009 | 01:18 PM
zman17's Avatar
zman17
This is one way to check the plenum http://dodgeram.info/tsb/2000/09-05-00.htm
As far as the cat goes, you need a infrared temp gun, or take it to a muffler shop and have them do a back pressure test, which is the best way to test it.
Old Jul 12, 2009 | 03:44 PM
97r/tram's Avatar
97r/tram
I'm about to do the vacuum test on the engine. I also cleared the code by disconnecting the battery and laying down on the horn. It usually takes 100 miles for it to come back on again. I didn't mention on the exhaust, I took off the stock muffler and I have a cherrybomb exiting in front of the passenger side tire. How much would this alter the backpressure in the cat?
Old Jul 16, 2009 | 12:43 PM
97r/tram's Avatar
97r/tram
I've now driven the truck over 200 miles since disconnecting the battery and holding down on the horn button to clear the computer memory of the p302 code. The cel hasn't come back on, but the truck is beginning to miss again and run kind of rough. It keeps fouling plugs in the #2 cylinder and every time i put in a new champion platinum plug, the motor runs smooth again for 100 miles or so. The truck isn't burning any oil and i'm thinking of trying another plug in that cylinder. Any opinions?
Old Jul 16, 2009 | 03:06 PM
jasonw's Avatar
jasonw
Site Moderator
Hate to be Captain Obvious here, but you keep on dealing with the symptoms, and not the problem.
Could be worn valve guides, the seals for said guides, or worn rings.
Old Jul 16, 2009 | 03:22 PM
zman17's Avatar
zman17
Or the plenum gasket that doesn't seem to have been checked yet.
