Lets help rebuild my engine :
Old Jul 6, 2009 | 05:03 PM
Activate's Avatar
Activate
Default Lets help rebuild my engine :
Ok the time is really there for a rebuild of my engine.
I am going to take the engine out to see waht is wrong with it.
Now I have these powerparts installed wich I want to use again : HS 1.7 rockers, Fastman 52 mm TB, Kenne Bell SC 10 PSI(the inlet gasket also leaking now) EQ ported and polished head only 1 year old, modified kegger.
I am going to weld the Alu belly pan to the Kegger, so no more problems with teh F***** gasket I hope.
I want more torque for towing and the campershell and more power is always welcome.
I think I need new rings and pistons so maybe build a stroker?
Wich (cheap) strokerset do I need?
Wich camshaft do I need?
I also want to change these parts : Timingset, Oilpump, for better ones.
What do I need more?
Building tips ar more then welcome!!
Thanks and greetings,
Erik.
Old Jul 6, 2009 | 10:13 PM
aim4squirrels's Avatar
aim4squirrels
I've never heard of anyone ever using a higher ratio rocker with a SC engine. Hope allowing too much into the CC wasn't your issue.
Old Jul 7, 2009 | 08:38 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Hit it with an axe!
Old Jul 7, 2009 | 11:02 AM
Activate's Avatar
Activate
I did but it still hurt my hands and wallet!!! LOL
Old Jul 7, 2009 | 12:40 PM
dodgeram07's Avatar
dodgeram07
OR
http://www.hughesengines.com/Index/p...=&partid=24773
you may able to use the rr with this but it would be close on lift plus with the sc no sure
http://www.hughesengines.com/Index/p...2&partid=11442
http://www.hughesengines.com/Index/p...Ryb2tlciBLaXRz
this is a sweet site with sweet cams and stocker kits
http://www.krcperformance.com/krc/in...hk=1&Itemid=26
Old Jul 10, 2009 | 04:21 PM
Activate's Avatar
Activate
This is the reason I am rebuilding:
