wheelin with bad tranny
Old Jul 7, 2009 | 06:50 PM
OLE BLUE97's Avatar
OLE BLUE97
Default wheelin with bad tranny
would it be a bad idea to go wheelin and muddin with a bad tranny. i havnt put my truck into 4wd in almost 6 months because im nervous my tranny will take a dump. it will bne light muddin and/or wheelin.
Old Jul 7, 2009 | 08:06 PM
Ram15002ndGen's Avatar
Ram15002ndGen
I think that would be a BAD idea. Going mudding will put a greater strain on the tranny. I think you may get stuck out there. Going 4x4 on a regular road shouldn't hurt any, if all you want to do is keep everything moving.
Old Jul 7, 2009 | 08:36 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Yes its a bad idea. How bad is bad?
Old Jul 7, 2009 | 09:11 PM
dhvaughan's Avatar
dhvaughan
no guts no glory. take a buddy, have a plan for failure and go for it.
t-case engaged in 2wd vs 4wd has absolutely no effect on tranny.
what's wrong with the trans ?
Old Jul 7, 2009 | 09:38 PM
OLE BLUE97's Avatar
OLE BLUE97
its rough shifting into second gear, and sometimes doesnt shift into third. im gonna have my tranny shop take a look at it tomorrow. i think it just needs to be reprogrammed.
so i can engage 4wd on the street?
oh and i wont be going any faster then 10mph with it on 4wd
Old Jul 7, 2009 | 11:02 PM
dhvaughan's Avatar
dhvaughan
its a bad idea to engage 4wd on dry pavement. thefront and rear binds up and something has to give, hopefully the tires slip but it just puts a lot of stress on everything. engage it all you want on a dirt road, but not on pavement.
i think you're fine to go wheeling.
Old Jul 7, 2009 | 11:21 PM
dodge15004x45.9
When I 1st got my truck And put it into 4wd. I was like great something is wrong. Than I found out its normal. I only use my 4wd when i'm really stuck now. Its been like 4 months.
Old Jul 8, 2009 | 12:20 AM
OLE BLUE97's Avatar
OLE BLUE97
so if im on a dirt road i should be fine? theres a big plot of dirt i can go drive around for a little bit.
Old Jul 8, 2009 | 12:29 AM
dodge15004x45.9
If it lose lose/mud. But I only use it when I'm in mud!
Old Jul 8, 2009 | 12:48 AM
jasonw's Avatar
jasonw
Site Moderator
The only part of our trannies that have anything to do with "programming" is OD. All the other gears are not controlled by the computer, they're mechanically controlled.
Therefore its highly unlikely a "reprogram" will fix anything, unless by "reprogram" you meant "a complete rebuild".
