Wheelhouse Liner Removal?
Old Jul 10, 2009 | 12:04 AM
EricCartman's Avatar
EricCartman
Default Wheelhouse Liner Removal?
I did a quick search... and didn't find any info, so I figured I would ask...
I looked in the FSM, and it appears that the wheelhouse liners (as they seem to be called) are held in by plastic rivets. I would like to remove these to have easy access to a few mods/wiring that I want to do...
Has anyone ever successfully removed & reattached these things? I'm pretty sure I can get them off... but since those are plastic rivets, I'm a little concerned with the ability to get them back on. Do these pop out like the plastic rivets that hold the door panels on?
Thanks,
Cartman
Old Jul 10, 2009 | 12:09 AM
wjxavier's Avatar
wjxavier
Usually, with those crappy plastic "rivets", I would suggest getting new ones. Once you pull them out, in the process you usually end up screwing up the spars and it will never hold true again.
Old Jul 10, 2009 | 12:11 AM
EricCartman
I thought that might be the case...
I did some looking around, turns out that HF sells a rivet gun and plastic rivets for relatively cheap:
http://www.harborfreight.com/cpi/cta...emnumber=97757
http://www.harborfreight.com/cpi/cta...emnumber=97753
Looks like it might be time to make a trip.
Cartman
Old Jul 11, 2009 | 10:47 PM
Trey318's Avatar
Trey318
Just use some standard plastic tree clips after you get the old rivets off. Makes removing it a lot easier when you need to.
Old Jul 11, 2009 | 11:53 PM
BlueBeast2's Avatar
BlueBeast2
They ain't the same as the door thingers. They are totally different. The wheel ones you use pliers on and can pull on the center part of them to "disengage" them then pull them out. Then when you put them back you push the center back down and it relocks them. I have done it before
Old Jul 12, 2009 | 02:35 PM
dhvaughan's Avatar
dhvaughan
i've reused the old one and had most of them hold ok. just pry them up with a screwdriver and get ahold of them with pliers and yank them out.
if necessary, you can buy replacements at autozone in packs of 6 or 8 or so.
what i did on my truck was replace them all with 1/4 bolts and nuts. i was chasing a rattle and thought the fender liner might be the culprit, so i bolted them up tight. works fine.
Old Jul 12, 2009 | 02:59 PM
Sheriff420's Avatar
Sheriff420
when i relocated my air horns i had to take mine loose and i just clipped the rivet off and used a nut/bolt like dhvaughan did.
