ALWAYS HAVE 3/4 TANK
Old Mar 21, 2005 | 07:19 PM
moparmania's Avatar
moparmania
Default ALWAYS HAVE 3/4 TANK
OK SO IM THINKING ..DANG IM GETTIN GREAT MILAGE NOW. BUT AFTER 30 MIN IT HITS ME THAT MY FEUL GAUGE IS TOAST. I HAVNT LOOKED IN THE BOOK YET, BUT THINKING ITS NOT GOING TO BE A FUN FIX. HAS ANYONE HAD TO CHANGE THIS, AND HAVE ANY TIPS FOR ME BEFORE I DIVE IN ????????????? THANKS
Old Mar 21, 2005 | 10:27 PM
_JB_'s Avatar
_JB_
Default RE: ALWAYS HAVE 3/4 TANK
Mine was messed up when we bought it, four years ago. Ran out of gas a few months ago and replaced it and was happy. For me the guage was bouncing all over the place. I replaced the pump, since the sending unit and pump are all in one, it was pricy. Just had to drop the tank, swap the pump, and it was done.
Old Mar 22, 2005 | 12:07 AM
steve05ram360's Avatar
steve05ram360
have you re-filled the tank yet? try that, it may bring it back. I had a similar problem a couple of times, (mine being at empty) and a few key cycles and a fillup fixed it (or I should say, it hasnt had a problem since then...)
Old Mar 22, 2005 | 02:39 AM
casper's Avatar
casper
Sounds like the sender might be bad.
Old Mar 22, 2005 | 03:26 AM
moparmania's Avatar
moparmania
i was hoping that a fill up might bring it back but it stays in the same position even with the key off.. is there ome type off sending unit outside the tank i should check first
and im wondering if the rumor i was told before is true that aditives can cause problems like these. i still doubt it
Old Mar 22, 2005 | 02:24 PM
steve05ram360
I doubt that additives would do this, however mositure in the tank would. It could get into the sending unit and cause rusting of the contacts in the sending unit.
Old Mar 22, 2005 | 09:19 PM
stic's Avatar
stic
ever notice that you can drive what seems like forever until you hit 1/2 tank.then it seems like overnight,its gone.
i can get 150mi on the upper half butless then 100 on the lower half.
just one of those things that make ya go hmmmmm????
hmmmm....
