for those that have dealt with AC issues
Old Jul 22, 2009 | 11:04 PM
  #21
Bdodge60's Avatar
Bdodge60
our trucks have a oriface tube system. That consist of a compressor, condensor, oriface tube, evaporator, accumilator.(in that order also). Alot of the time the oriface tube gets plugged and the suction line does not get cold. (EVACAUTE THE SYSTEM OF FREON PROPERLY)then the accumilator should be replaced because it it is over 10 years old, and note the amount of oil trapped in the accumalator once you take it off. All the o rings should be replaced. and also make sure the compressor is ingauging properly. you should then get the vehicle vaccumed down for at least 15 min. and also do leak test. then you should add which ever pag oil is required. a rule of thumb is 1 ounce per pound of freon.(not including the amount lost in accumilator). Then Add the suggested amount of r134(should say under hood in # units). Then you should add dye and run vehicle on recerculate medium fan speed with a thermometer in the middle dash vent. The temp should get down to 35-45 F. Then you should check for leaks with black lights and uv glasses. IN OTHER WORDS LEAVE IT TO THE PROFESSIONALS IT WOULD BE A LOT QUICKER AND SIMPLER ON YOUR PART.
Old Jul 31, 2009 | 12:34 AM
  #22
dieselndixie's Avatar
dieselndixie
ok, well.
i put a wire "jumper" in the plug that goes onto the top of the accumulator. this forced the compressor to turn on. truck immediately showed empty, and after 2 cans of refridg/sealer it shows full and the a/c is cold as hell. jumper removed, plug put back in place on accumulator. compressor now comes on by itself when the a/c is on
done
Old Aug 3, 2009 | 03:09 PM
  #23
dieselndixie
no comments? so, how did no one tell me to do just what I did? I called a local A/C shop before I fixed it myself. If I would have LEFT IT TO A PROFESSIONAL, I would have overpaid by about $150
take forum advice as just that....advice
Old Aug 3, 2009 | 03:15 PM
  #24
pavement_hater's Avatar
pavement_hater
I will comment. If it was low, it was for a reason. Somewhere there is a leak. You will have this problem again. Maybe not next week or even next month but it will stop working again.
Old Aug 3, 2009 | 03:17 PM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
Well, If you would have done a search on here to begin with noob, you would have seen that I and other members on here have suggested that in other threads. And besides, there is a reason it's empty. So good luck, bud! Have fun replacing the evap core eventually or LEAVE IT TO A PROFFESIONAL!
Old Aug 3, 2009 | 08:09 PM
  #26
Ram15002ndGen's Avatar
Ram15002ndGen
That's a real good way to gain the help of other, to cut them down when they try to help. Well, I guess you learned a valuable lesson, you get what you pay for. If you didn't like the advice that was given, remember what you paid for it, $0.00.
