trouble code P-1258?
Old Jul 12, 2009 | 05:04 PM
Rockyhigh360's Avatar
Rockyhigh360
Default trouble code P-1258?
All the codes in my Chiltons are P-zero codes, none begin with 1. Anybody have any ideas? This check engine light drives me nuts.
Old Jul 12, 2009 | 05:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It pretty much means that it has been overheated at one point or another. Reset the PCM and see if it comes up again.
Old Jul 14, 2009 | 06:07 PM
Rockyhigh360
Nope, not overheating at all, in fact, cool as the otherside of the pillow. What is the actual definition of P-1258?
Old Jul 14, 2009 | 06:10 PM
wjxavier's Avatar
wjxavier
I believe its a code that gets displayed after the temperature has gone above a certain point at any time.
Old Jul 14, 2009 | 06:22 PM
jasonw's Avatar
jasonw
Site Moderator
P1258 Engine Coolant Over Temperature - Protection Mode Active
I believe the "certain point" is around 268 degrees F. Basically, the computer registered that the coolant at some point was over 268 degrees F and went into "protection mode" to try and save itself.
Do not get this confused with the P1258 for Diesel engines, which is different.
Old Jul 14, 2009 | 09:45 PM
Rockyhigh360
Well, just replaced the radiator, t-stat, water pump, flushed trans lines and cooler, and added royal purple ice about 300 miles ago when I replaced trans and few other things. Might be the new coolant temp sensor in the new F.I. air gap. It might be screwed in to far and getting to hot? This truck NEVER overheats and has been taken easy since the new work for break-in reasons. Any other ideas?
Old Jul 15, 2009 | 01:54 AM
jasonw's Avatar
jasonw
Site Moderator
Have you cleared the code and had it come back?
Old Jul 15, 2009 | 09:52 PM
Rockyhigh360
Yes, code cleared and nothing yet, only after 20 miles.
