Few pics, installed a few things.
Old Jul 15, 2009 | 12:55 PM
lb79theone's Avatar
lb79theone
From: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
Looks good bro!
Old Jul 15, 2009 | 01:18 PM
Sheriff420's Avatar
Sheriff420
that engine is too clean.
Old Jul 15, 2009 | 02:16 PM
RamSport97's Avatar
RamSport97
Thanks fellas for the compliments. The engine is sort of clean haha, I have a valve cover gasket leak on the passenger side toward the back near cylinder 8 I believe. I saw that the header was a little saturated and there was oil buildup around the lip of the valve cover. I tightened the bolts that I could but I really just need to replace the gaskets. That probably accounts for the reason I am losing 1.5 quarts or so every oil change. Looked down the TB and no oil pools, so I believe the plenum is fine.
Old Jul 15, 2009 | 02:25 PM
Ram15002ndGen's Avatar
Ram15002ndGen
I think I read on another post that the valve cover gaskets are reusable on these trucks? I could be wrong, someone else can correct me if I'm wrong. I've never changed mine. When I had a minor leak a while back, I just tightened it up and problem solved.
Old Jul 15, 2009 | 02:42 PM
Sheriff420's Avatar
Sheriff420
they are re-usable. they are metal reinforced rubber tightened to 95" lbs. they tend to get loose on the magnum engines, probably because the gasket is thick and squishy and the torque is pretty low on the bolts. i just replaced mine a month ago and i had 5 loose bolts on each cover. the originals looked pretty bad too so i went with the new ones.
Old Jul 15, 2009 | 03:18 PM
PurplDodge's Avatar
PurplDodge
Nice shocks....And the 14x3.
Old Jul 15, 2009 | 07:32 PM
lastrights's Avatar
lastrights
nice truck, did you put in the heavy duty or the offroad billsteins
Old Jul 15, 2009 | 09:34 PM
RamSport97's Avatar
RamSport97
Thanks guys, well thats good to know they are re-usable. I will take off those pain in the *** clips on some of the bolts and torque them down. And they are the heavy duty Bilsteins.
Old Jul 15, 2009 | 10:09 PM
96rumbledodge's Avatar
96rumbledodge
that is a clean sport
you can always tell when the owner of a vehicle really takes care of it and shows pride in what they drive
Old Jul 15, 2009 | 10:21 PM
95MaroonMonster's Avatar
95MaroonMonster
Originally Posted by Hammer Down
That aircleaner looks sharp... and strangely familiar.
yea, i was gonna say the same thing, but thats way too clean to be mine
