Trac Bar Bushing
Old Jul 14, 2009 | 09:34 PM
mjackson92rs's Avatar
mjackson92rs
Default Trac Bar Bushing
Track Bar bushing - do you need a press to get it out?
Thanks.
Old Jul 15, 2009 | 02:00 AM
jasonw's Avatar
jasonw
Site Moderator
Are you sure the track bar is still OK? Usually by the time the bushing needs replacing, its time to replace the track bar itself.
Old Jul 15, 2009 | 09:48 AM
mjackson92rs
putting on a lukes link and new bushing. the bar itself is near impossible to go bad.
now back to original question.
Old Jul 15, 2009 | 12:58 PM
dsertdog56's Avatar
dsertdog56
Yes its a press out...although I'd probably torch it out since it's rubber. Curious...Are you replacing it with a rubber or urethane product?
Old Jul 15, 2009 | 01:13 PM
mjackson92rs
urthane. dsertdog, does the metal sleeve inside of the trac bar stay in and just the rubber comes out? or does the whole assembly, metal housing and all come out?
Old Jul 15, 2009 | 02:40 PM
dsertdog56's Avatar
dsertdog56
I believe in order to fit the urethane you will have to remove the sleeve. But I would suggest consulting the bushing mfr. My experience with urethane bushings doesn't cover the track bar, but I had to "remove" everything when I redid my rear leafs.
Old Jul 15, 2009 | 06:15 PM
jasonw's Avatar
jasonw
Site Moderator
B.S. The bushing end, no, but the tie rod end of it goes bad on the stock unit quite often.
Old Jul 15, 2009 | 10:45 PM
mjackson92rs
Replaced the ball joint end with a Lukes Link. Check it out:
http://www.lukeslink.com/
Old Jul 16, 2009 | 02:22 AM
jasonw's Avatar
jasonw
Site Moderator
Got ya. Interesting idea.
I apologize, I figured Lukes Link was something to do with the bushing end. Then you said they never go bad, so I assumed you meant the tire rod end, and I was like "WTF???"
Thanks for clearing it up.
