46rh in a truck that came with 46rh
Old Jul 16, 2009 | 10:24 PM
jbomb's Avatar
jbomb
Default 46rh in a truck that came with 46rh
This is a question to the tranny experts on the forum. Has anyone put a 46rh in a truck that came with the re? Is the only difference the valve body and some electrical connections. Thoughts? Bro is going to buy a 2001 off road and wants to use the older tranny tho.
Old Jul 16, 2009 | 10:48 PM
Miami_Son's Avatar
Miami_Son
Too bad you messed up your thread title.
Old Jul 17, 2009 | 04:00 AM
jasonw's Avatar
jasonw
Site Moderator
We have a tranny expert, Monte C, here that can best answer your question. I'd wait for him to jump in before doing anything.
The electrical connections are not just "some electrical connections", they are 100% necessary for the transmission to shift properly since O/D is controlled by the PCM.
Old Jul 17, 2009 | 06:38 PM
dblj16380's Avatar
dblj16380
From most questions posted about this topic they usually recommend swapping the computer too. I am pretty sure that you will run into tons of problems using a computer programmed for a 46RE and a 46RH trans.
Old Jul 21, 2009 | 09:13 PM
MonteC's Avatar
MonteC
Too much work for essentially the same transmission. If you maintain the RE properly (clean the gov. solenoids on every fluid change), it will last just as long as the RH unit. The only thing comparable with the two units are the gear sets.
Old Jul 21, 2009 | 09:40 PM
Jr. Mechanic's Avatar
Jr. Mechanic
The 46RH is slightly longer than the 46RE meaning you would need to modify you drive shafts aswell.
Old Jul 21, 2009 | 11:54 PM
Trey318's Avatar
Trey318
Off topic, but nice Camaro! You've got ***** to post a chevy as your only picture in your sig on a dodge forum :P.
Old Jul 22, 2009 | 01:46 AM
Miami_Son's Avatar
Miami_Son
Originally Posted by MonteC
(clean the gov. solenoids on every fluid change).
Exactly how is this done?
Old Jul 22, 2009 | 01:52 AM
dodge15004x45.9's Avatar
dodge15004x45.9
By taking them out when you drop the pan.
Old Jul 22, 2009 | 02:19 AM
Miami_Son's Avatar
Miami_Son
OK, smarty, What's involved? Do you need to drop the valve body?
