Blower motor issue
Old Jul 16, 2009 | 10:54 PM
torp74's Avatar
torp74
Default Blower motor issue
My blower motor won't run. I pulled it, hooked it up directly to 12V, and it spun like crazy. I replaced the blower motor resistor @ $82 and still no joy. I then tested the blower motor relay as per the Haynes manual, and it tested good. I am at a loss, have searched and googled, and don't know what else to check. I would appreciate any ideas.
Old Jul 19, 2009 | 06:32 PM
torp74's Avatar
torp74
Alrighty then.... Don't everyone reply at once. I'm sure someone else has had this problem. I just need help ferreting out these electrical bugs.
Old Jul 19, 2009 | 06:50 PM
Ram15002ndGen's Avatar
Ram15002ndGen
If you checked the blower, the fuses, the relays, have you checked the switch? Then the only thing left is a loose ground, or a wire somewhere that is not transmitting power to the right place. You have to trace back the power lines and see where the break is. This is one of those tedious jobs of pin the multimeter on the problem wire.
Old Jul 19, 2009 | 10:00 PM
dodgeram2001's Avatar
dodgeram2001
u could just make a switch and all just do that if u cant get it to work the right way
Old Jul 20, 2009 | 11:22 AM
Sheriff420's Avatar
Sheriff420
check for power at the plug for the blower motor since you haven't done that yet.
Old Jul 20, 2009 | 11:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you check the fuse or only the relay? Did you check for power at the fuse? And if you did check the fuse, did you do it visually or with an ohm meter or swap it with another 10 amp?
BTW, I'm sorry that everyone that has had a blower motor problem on here wasn't waiting for your thread and didn't reply to it 5 minutes later. LOL It's not like that is a major issue on these trucks.
Old Jul 20, 2009 | 12:50 PM
torp74's Avatar
torp74
I do appreciate everybody's help on this. I dont have power going to the fan, so I think I might be looking at a faulty ground. Will run it to ground this weekend. Thank you all again for your help.
