Fog light questions
Old Jul 17, 2009 | 03:06 AM
2001Ram's Avatar
2001Ram
Default Fog light questions
So, on my 2001 Dodge ram it didnt come with fog lights from the factory, but I reallly want to add them. What all will this involve? I belive the local junkyard has a Ram with fog lights. Should I get those if they are nice or get new ones?
Thanks!
Ryan
Old Jul 17, 2009 | 03:37 AM
jasonw's Avatar
jasonw
Site Moderator
All it involves is a nice set of aftermarkets or junkyard fogs, and then wiring to a switch inside the cab. Mine are real glass lensed with steel housings that I purchased off a seller on eBay for approximately $40 or so. Wired them to a HD switch inside the cab and there ya are.
3" to 4" should fit just fine.
Old Jul 17, 2009 | 12:33 PM
Sheriff420's Avatar
Sheriff420
https://dodgeforum.com/forum/2nd-gen...-question.html
adding the factory fogs will involve cutting your bumper a little and some $$$. factory fog lights with the mounting brackets aren't cheap.
Old Jul 17, 2009 | 02:07 PM
Ram15002ndGen's Avatar
Ram15002ndGen
I depends if you want to go after market or stock. Stockers mean you need stock fogs, new light switch, and cutting your bumper. Price will vary. After market, is cheaper, comes with all you need and no bumper cutting. I got mine at WalMart for $20, they fit perfectly, and I didn't have to cut the bumper. I could take them out and you wouldn't even know I had had them in there. Comes with wiring and rocker switch. Pick your poison.
Old Jul 17, 2009 | 03:50 PM
2001Ram's Avatar
2001Ram
So I would like to get the headlight switch that has the fog light built in, but the aftermarket sounds better. Is there a way to do that?
What is the correct one to buy at wal mart?
Thanks for all yalls help!
Ryan
Old Jul 17, 2009 | 03:52 PM
2001Ram's Avatar
2001Ram
What are the best ones to buy at walmart? Which ones did you buy i mean, yours look great in your sig. I would really like to get the original headlight fog switch, but I wouldnt mind after market fogs..
Will that work?
Thanks for all the help guys!
Ryan
Old Jul 17, 2009 | 04:17 PM
Sheriff420's Avatar
Sheriff420
the best ones to buy at walmart are the ones that fit. just make sure you get some with glass lenses.
Old Jul 17, 2009 | 06:24 PM
Ram15002ndGen
The ones I got at WalMart do have the glass lens, and they have the blue tint light bulbs. They light up really good at night (that really bright white light) and help to augment the stock head lamps. Every WalMart is bound to carry different stock. Mine came in a black box, they were $19.99, they were 4" lights I believe, and they had a light blue bulb in them. They also had no frame around the lens, which was important to me since I wanted to match the stock look. At the store I went to they were the only plain ones they had. The others were either way to small, or way to ricer, or off road stuff like what Sheriff has on his brush guard. I hope your store has them.
Old Jul 18, 2009 | 10:44 PM
tango-52's Avatar
tango-52
I have a 2001 Ram 2500 that did not come with fog lights stock. I went to a junk yard and got the OEM fog switch, harness, and relay. I then added an after-market set of lights. They work great and it was an easy install. No new wire to run, no new switches to mount. Cost me $25 for the stock junk yard parts and $40 for the fogs that fit the round holes in the stock bumper.
Old Jul 18, 2009 | 11:19 PM
2001Ram's Avatar
2001Ram
Awesome, thats the plan for me. The problem is that most dodges in the Junk yards are either hit or plane jane work trucks. I guess there isnt many in the junk yards because there are so many still on the road! :-D
Anyway thanks everyone for yalls help
Ryan
