P0441 code and truck dying!!
Old Jul 18, 2009 | 02:00 PM
hondarider's Avatar
hondarider
Default P0441 code and truck dying!!
Check engine light turned on so I had my codes ran, and it said it was P0441 which is evap purge fault. When the truck has a cold start, it runs fine but once you start driving, it dies out at stops. I pulled two hoses off of the canister, and one was pouring out small peices of charcol and you could tell the canister was filled with loose charcol. Would this mean I have to replace the canister? And if so what else should I do?
Thanks
Old Jul 18, 2009 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Charcoal in the hose = not a good sign. I would replace it and the solenoid and blow the hoses out before re installing them.
Old Jul 18, 2009 | 05:16 PM
hondarider's Avatar
hondarider
Where is the solenoid located?
Old Jul 19, 2009 | 07:28 AM
zman17's Avatar
zman17
I forgot to bust your ***** for not putting all the info about your truck in your sig! It matters what year it is, and until you do so, I ain't tellin' , LOL
Old Jul 19, 2009 | 07:05 PM
hondarider's Avatar
hondarider
Ok is the vapor canister supposed to have solid charcoal in it?
Old Jul 20, 2009 | 06:44 AM
zman17's Avatar
zman17
Yes, and since you have a 97 , the solenoid is either mounted on the back of the drivers valve cover , or on the passenger side inner fender well, if you have not figured that out already.
