Gear question
Old Jul 18, 2009 | 06:33 PM
BigRedRam95's Avatar
BigRedRam95
Default Gear question
Do any of you guys know what a High Pinion/ Reverse Rotation gear is also I found a set of dand 44 thick gears but the guy told me the gears use a 7/16" ring gear bolt instead of the more common 3/8" bolts. and the ring gear bolt holes must be drilled out slightly from 3/8" to 7/16". Is this bad to do or not I just dont know much about gears Thanks
Old Jul 18, 2009 | 07:07 PM
Miami_Son's Avatar
Miami_Son
A high pinion/reverse rotation is a type of axle housing where the pinion gear enters the top of the pumpkin instead of at the bottom like average axles. It is commonly used in applications where the lift is so high that the driveshaft angle will be too severe with a standard axle. Rockwell axles use this type of setup.
Old Jul 18, 2009 | 07:19 PM
BigRedRam95
This is what the guy told me Jeep JK Wrangler Rubicon Front High Pinion/ Reverse Rotation 4.10 matching Ring and Pinion Gear set for Front JK Rubicon Dana 44s. Dana/ Spicer Brand. Used, but in excellent condition. No unusual or excessive wear. Great condition. Low Miles can I use this in my truck
Old Jul 18, 2009 | 08:47 PM
Miami_Son's Avatar
Miami_Son
There are a number of different versions of the Dana 44. I doubt one from a Jeep as you've described it would fit without needing some degree of fabrication. If it was designed for a leaf spring front end it won't work. Rock crawlers love those axles, but they use them on long suspension setups. If you have a mildly lifted truck it probably isn't worth the effort to make it fit.
Old Jul 18, 2009 | 10:03 PM
BigRedRam95
Well this is just the gears not the whole front end
Old Jul 18, 2009 | 10:41 PM
Miami_Son's Avatar
Miami_Son
I'm pretty sure those gears won't work in your stock pumpkin. If they are reverse rotation, then definitely not.
Old Jul 18, 2009 | 10:57 PM
BigRedRam95
ok thanks
Old Jul 18, 2009 | 11:02 PM
BigRedRam95
Do you know what the guy was talking about when he said the gears use a 7/16" ring gear bolt instead of the more common 3/8" bolts. and the ring gear bolt holes must be drilled out slightly from 3/8" to 7/16". Is that just a hole the bolts go through would it be bad to drill them out
Old Jul 18, 2009 | 11:11 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Ok dude this is one of the times you don't want to cheap out. Buy new gears. Rockwell axles are top of the line. Some Day I want 44" tires and 2.5 ton rockwells.
Old Jul 18, 2009 | 11:15 PM
dodge15004x45.9
Here is a good site with VERY good prices.
http://completeoffroad.com/c-69615-d...-packages.html
http://completeoffroad.com/c-59859-chrysler-9-25.html
