Removal of plastic in front of dash gauges! (For cleaning).
Old Jul 18, 2009 | 10:18 PM
lb79theone's Avatar
lb79theone
From: Maine! ( GET A HOLD OF ME IF YOU WANT TO GET ME ON FACEBOOK.COM, AND CARDOMAIN.COM)
Question Removal of plastic in front of dash gauges! (For cleaning).
I was just wondering if there was a way to remove the clear plastic in front of the gauges in my dash of my 2nd gen.? I want to know so I could clean the dust and stuff behind it? Could this be done easy or hard etc.
Thanks in advance!
Brendon.
Old Jul 18, 2009 | 10:39 PM
volkstony's Avatar
volkstony
Default re:
its not that hard to do you have to remove the front black dash panel once removed they are a number of screws that hold the clear plastic gauge cover in place. good luck
Old Jul 18, 2009 | 11:37 PM
2001Ram's Avatar
2001Ram
be carefull, as we all know dodge dashes and plastic SUCK and when I tried to do this a huge chunk cracked off. Then all the tabs broke so now it rattles like crazy.. UGh.
Old Jul 18, 2009 | 11:40 PM
Laramie1997's Avatar
Laramie1997
Just take your time, and remove the front dash plate. Under that, there should be about four (4) screws to remove. Once you have those out, carefully lift the clear plastic out.
Old Jul 19, 2009 | 12:32 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Use a very soft brush to dust the gauges. You don't want to break them.
Old Jul 19, 2009 | 12:37 AM
Laramie1997
I just use canned air around the gauges..............
Old Jul 19, 2009 | 02:11 AM
Oren09's Avatar
Oren09
Be careful.
The clear plastic is fragile along with all the other dash parts... I cracked mine just over the temp gauge when I detailed my interior.
Old Jul 19, 2009 | 02:22 AM
Miami_Son's Avatar
Miami_Son
Originally Posted by Oren09
Be careful.
What do you detail with, whips and chains?
Old Jul 19, 2009 | 02:28 AM
2001Ram's Avatar
2001Ram
HA! There wouldnt be an interior left if that was the case.. lol
Dodge sure can build a motor but when it comes to plastic... they had better be
Old Jul 19, 2009 | 02:59 AM
Oren09's Avatar
Oren09
Windex and paper towels, actually.
