Bearing rattle??
Old Jul 19, 2009 | 11:34 PM
Cheesehead's Avatar
Cheesehead
Default Bearing rattle??
I have had a rattle underload occasionally. Today pulling a camper and having to pull out in traffic i gave it the gas and heard a serious metal tapping like something was coming out of the engine. After I got out of it the noise subsided...baby'd the throttle and pressed on. As I was moving up and down the hills on my way home things seemed fine. If I kept the rpm's high and the tranny in a lower gear there seemed to be no problems. I drove it 100 miles up and down some pretty steep terrains. I have good oil pressure and no heat problems. Is there a possible spun bearing or something that I might have going on?
Would this be a rebuild?
Should I say my prayers for making it home?
01 Ram 4x4 5.9
Jeff
Old Jul 20, 2009 | 07:18 AM
dhvaughan's Avatar
dhvaughan
could it be spark knock (pinging) ?
its a common problem with these trucks.
lots of info on this site under "plenum" and "pinging"
edit- a quick and easy test is to fill up with highest octane gas to see if its reduced or eliminated.
usually, a true metal on metal knock happens all the time, and not just under load.
Old Jul 20, 2009 | 08:53 AM
charlie1935's Avatar
charlie1935
Main bearing knock will show under load but you said the oil pressure is good so I wouldn't think it was them. They make a deep heavy knock, not a rattling or light sounding knock.
How many miles on the engine and any oil consumption?
Old Jul 20, 2009 | 12:23 PM
Cheesehead's Avatar
Cheesehead
127k just had the oil changed last thurs before the trip. It does use oil but I watch that all the time. I heard a hard metal on metal type tapping when i first took off but nothing since. Even pulling up the steep inclines. Started it this morning no abnormal noises, rev'd her up a bit still nothing.
