P0123 (TPS volt hight) and AC problem??
Old Jul 20, 2009 | 10:35 PM
Twotone's Avatar
Twotone
Default P0123 (TPS volt hight) and AC problem??
Hey!
We've got a 2000 5.9 Gas here and when its running with AC off everything fine. As soon as we turn on the AC the TPS read 4.92 volts and triggers the code.
Ive replaced the PCM and TPS no change. This was after probing and doing pinouts. I can't seem to find anything wrong except on the Org/blue wire from the TPS (TPS line in to pcm) it was reading 4.92 with the truck off. I bypassed the AC switches (no change) Unplugged the compressor while running (No change)...
Please help!
Old Jul 21, 2009 | 07:49 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The IAC on back of the TB may be the problem. Remove it and clean it, and the bore in goes in to on the TB. Don't spin it or push it in when cleaning. Just spray it off and reinstall when dry. It's free to try anyway.
Old Jul 21, 2009 | 08:33 AM
aim4squirrels's Avatar
aim4squirrels
might have a short in the wiring harness as the TPS and A/C sensors run down the same harness.
Old Jul 27, 2009 | 01:53 PM
Twotone's Avatar
Twotone
Ended up being a programming issue with the freakin command start...ARG!
Thanks to all that posted!
Old Jul 27, 2009 | 02:11 PM
zman17's Avatar
zman17
Glad you got it figured out, I'm also glad you gave me another reason for not wasting money on a remote start. Only problem is, that this is the second post today, that it was the remote start as the cause . Now I have to recommend that instead of the plenum gasket. Damn, thought the plenum suggestion would keep me good for a while.
Old Jul 27, 2009 | 05:55 PM
dhvaughan's Avatar
dhvaughan
i would have never guessed this one...
sounds like a remote start is just something else to screw up.
