Grinding noise while making sharp turn
Old Mar 23, 2005 | 02:43 AM
hayme's Avatar
hayme
Default Grinding noise while making sharp turn
Hello,
first I'd like to say hi to everyone in the board
I recently purchased an '96 Dodge Ram 1500 4X4, and I noticed that when I make a sharp turn I hear this awful grinding metal to metal noise. Does anyone have this problem? or anyone know the cause of it?
thank you very much !
Old Mar 23, 2005 | 05:21 AM
horatio102's Avatar
horatio102
Default RE: Grinding noise while making sharp turn
I've got a metal on metal grinding noise in my 5.0, but that's the wheel rubbing on the a-arm due to the wider wheel. You have stock wheels? Is the tire rubbing anywhere (fender, steering components, etc)?
Old Mar 30, 2005 | 04:31 AM
moparmark's Avatar
moparmark
hello, i had the same thing happen to me in my 99 2wd 5.9, a collapsed calliper on the front drivers side brake. it would grind whenever i would turn the wheel all the way to the left, in parking lots for example.
i replaced the pads and the callipers and it hasnt happened since.
Old Mar 30, 2005 | 04:49 AM
casper's Avatar
casper
If all the parts are not rubbing and the brakes are good, it could be the CV joints. How many miles are on the truck?
