Vacuum leak...confirm my suspicion
Old Jul 21, 2009 | 06:37 PM
MikeRWK's Avatar
MikeRWK
Default Vacuum leak...confirm my suspicion
Ok so i got a 95 ram 1500 the other day and it has a BAD vacuum leak! When i put my thumb over the end of the hose that runs from the valvecover breather to the airbox ontop of the tb it has alot of vacuum, is this a sign of a leaking intake gasket?
Checked it against our 96 ram with same engine and the 96 doesnt pull near as much vacuum
Old Jul 21, 2009 | 06:46 PM
Sheriff420's Avatar
Sheriff420
http://dodgeram.info/tsb/2000/09-05-00.htm
read that
Old Jul 21, 2009 | 06:49 PM
MikeRWK's Avatar
MikeRWK
I can hear it whistling from the front of the engine, and i've checked all the vacuum hoses and cleaned the IAC.
Old Jul 21, 2009 | 06:58 PM
MikeRWK's Avatar
MikeRWK
its also building enough pressure to suck the hose to my thumb which my 96 doesnt do.
Old Jul 21, 2009 | 07:22 PM
Sheriff420's Avatar
Sheriff420
you have to pull the pcv hose and plug it and the port that it plugs into, then run the truck for 30 seconds and see if you have vacuum at the crank case breather hose. if you do then you have a leaky plenum gasket. did you read the tsb?
Old Jul 21, 2009 | 07:28 PM
MikeRWK's Avatar
MikeRWK
yes i did, but its aparent that my truck is pulling way more vacuum then the 96.
