tb space
Old Jul 22, 2009 | 11:16 AM
360mag45's Avatar
360mag45
Default tb space
ok i got a 1" tb spacer for my truck can i still use that one and put the 14x3 air cleaner on or will it be to tall. or do i just need to down size to the 10x2.
Old Jul 22, 2009 | 11:20 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If you are talking about a TB spacer between the TB and intake manifold, take it off! It is just "taking up space" so to speak.
audiomechanic's Avatar
audiomechanic
Return the spacer. Keep the 14X3" air cleaner.
The spacer does nothing except limit your air cleaner choices.
Old Jul 22, 2009 | 11:22 AM
360mag45's Avatar
360mag45
ok i was just wondering because the diy thing said about haveing a 1/2" spacer
Old Jul 22, 2009 | 11:44 AM
zman17's Avatar
zman17
So do you have a TB spacer between the TB and intake manifold?
Old Jul 22, 2009 | 11:45 AM
Sheriff420's Avatar
Sheriff420
the only time you need a spacer with a 14x3 is if you have a drop base on the air cleaner housing. the spacer goes between the housing and the tb. as far as a 1 inch spacer under the tb, its worthless but if you want to keep it on there then you could get a 14x2 (if they even have that size). that wouldn't let as much air through though.
Old Jul 22, 2009 | 02:54 PM
audiomechanic
Good call, Sheriff. Forgot about the air cleaner spacers. I have the Edlebrock 14X3 (forgot the model number) and it looks as though it has a drop, but it's flush. It sits directly on top of the throttle cable braket. It's tight, but fits and nothing binds.
Old Jul 22, 2009 | 03:09 PM
Sheriff420's Avatar
Sheriff420
if it is on the cables then you might want to get a mirror under it to make sure it seals against the tb when the wing nut is tightened down. otherwise you'll be pulling in unfiltered air.
Old Jul 22, 2009 | 03:37 PM
zman17's Avatar
zman17
What? Good call? NO SHIP(T) And without knowing what the hell the OP has on there or what he's talking about, the previous replies are all obvious!!!! And besides that, if he is talking about a 1" spacer between the TB and the round air cleaner, then that's just dumb.(Sounds like he wants to install a 14X3, so why would there be a 1 inch spacer there with a stock intake) Take the F'n thing off and use a shorter one. Sorry to sound like an *** but wtf? This topic has been discussed so many time's it's ridiculous. Not to mention, I'd like to know what he means by "I have a spacer"? Does that mean he has one in his hand or installed on the vehicle?
Old Jul 22, 2009 | 03:55 PM
audiomechanic
It's sealing. I've got it sitting on top of the stock 'fiber' air box gasket and I also slit a rubber hose down the side and place that over the bottom ring of the air cleaner. It seals.
