irratic idle
Old Jul 26, 2009 | 07:51 PM
MAJohns's Avatar
MAJohns
ok thanx guys i will check it tomorrow i got the plugs and cap button and wires changes and it started raining so i will check it tomorrow. and by the way. my son was born on july 24 at 12:31pm 8lbs 3oz 19 1/2 in long! we are finaly home and i am tired of being cooped up inside so i am glad to work on my truck! thanx again!
Old Jul 29, 2009 | 08:57 PM
beaseac's Avatar
beaseac
Have you figured out what is causing this? My truck is having the exact same problem but it's now at the point where if I don't hit the gas it gets worse and sometimes even stalls. I have replaced the cap, rotor, wires, spark plugs, plenum gasket (x2), throttle body gasket and idle air sensor (x2). I think it has to be something with the PCM but I don't know for sure. A while back I sprayed some carb cleaner into the idle air motor area and it calmed down for a bit.
Any ideas?
1998 Dodge Ram 1500 4x4 5.9L
Old Jul 29, 2009 | 09:00 PM
beaseac's Avatar
beaseac
BTW, there are no stored codes in the computer.
Old Jul 29, 2009 | 09:33 PM
Hahns5.2's Avatar
Hahns5.2
On cold starts mine also ran like it had a big cam in it, and you could hear the IAC sucking air for a few seconds and then it would close up and idle smooth. It never bothered me, I kinda liked the sound but it went away as soon as I installed the Mopar PCM
Old Jul 29, 2009 | 10:26 PM
beaseac's Avatar
beaseac
If you don't mind me asking, where did you get the Mopar PCM and how much was it? Did you have to get it reprogrammed?
I was looking around and I found a place that sold rebuilt PCM's and would program it to match the truck for about $309 shipped (ebay I believe).
Thanks!
Old Jul 29, 2009 | 11:36 PM
Hahns5.2's Avatar
Hahns5.2
Thanks!
I bought it used for a steal at $115 shipped. It comes from Mopar with a custom "tune" in it already.
Jegs still carries them for select years.
http://www.jegs.com/p/Mopar-Performa...47011/10002/-1
Old Aug 1, 2009 | 01:00 PM
Formosa Joe's Avatar
Formosa Joe
Thumbs up
My '95 Ram 5.2L ran the same way. I replaced wires, cap, button, plugs and #2 injector. All the codes and backfiring went away, but still had idle issues. Cleaned throttlebody while still on the intake and the problem cleared up for a while. Now it started stalling at stop signs and lights, and especially when I burped the throttle (eg moving up in a drive thru).
I pulled the IAC, cleaned it and sprayed the port where the IAC is mounted, took 3 Q-tips and swabbed the inside of the port (careful not to leave any lint behind). This cleared all my idle problems. I can burp the throttle with no probs and it seems to have better throttle response and the hesitation is gone. There is alot to be said about proper cleaning of the throttlebody. Hope this helps.
