hey stroker guys......
Old Jul 24, 2009 | 12:14 AM
cool hand luke's Avatar
cool hand luke
Default hey stroker guys......
ive been dreaming of stroking my 318 into a 390 with the hughes stroker kit. i know how much it will help with my low end numbers, but would i be sacrificing top end performance or reliability?
Old Jul 24, 2009 | 01:10 AM
cool hand luke
come on guys. help a brother out. its my dream to rebuild this 98 318. new cam, tri metal bearings. stroker kit, iron ram heads with a mild port. but im unsure if the stroker kit would make performance above 3500 unreliable. what problems would i run into with the sroker motor?
Old Jul 24, 2009 | 02:01 PM
helms's Avatar
helms
these engines hardly have a "top end" lol. i would consider 3500-4000 mid range. and the answer is no.
You have the right idea. the longer stroke will demand more air at any given RPM, but i think the magnum heads flow pretty good, you would probobly only see flow issues when getting close to 6000rpm.
A better flowing exhaust and intake is a must, but the heads should have no problem supporting 390ci under 5500RPM
Old Jul 24, 2009 | 03:06 PM
cool hand luke
thanks helms. she already breathes pretty easily, but i doubt i wanna see the motor turn any more than 5500. its still a bit of a work horse. and the stroker would help hauling and towing i believe
Old Jul 24, 2009 | 06:17 PM
helms's Avatar
helms
definatly. when my engine kicks it, i plan on rebuilding it as a 408.
