need answer asap
Old Jul 25, 2009 | 12:18 PM
snooked321's Avatar
snooked321
Question need answer asap
I am in the begining of replacing the plenum gasket. I am draining the coolant fluid and need to know if i need to also drain the block or is it ok to just drain it from the radiator drain?
Old Jul 25, 2009 | 12:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do yourself a favor and remove the lower radiator hose from the rad. It will lower the level enough.
Old Jul 25, 2009 | 12:25 PM
snooked321's Avatar
snooked321
thank you very much
Old Jul 25, 2009 | 12:38 PM
zman17's Avatar
zman17
NP, just remove it off slowly and have a drain pan ready obviously.
Old Jul 25, 2009 | 01:07 PM
snooked321's Avatar
snooked321
removed the hose to the water pump after draining the radiator and nadda nothing, I figure I should be safe??
Old Jul 25, 2009 | 01:12 PM
zman17's Avatar
zman17
You are good, either way. Just removing the lower hose from the rad is alot quicker, and more messy.
