pics of plenum r/r
Old Jul 26, 2009 | 06:47 PM
  #21
2damnyankee's Avatar
2damnyankee
Originally Posted by snooked321
OK stupid question: huges plate instructions say 48 inch pounds then 84 inch pounds, my torqe wrench is in foot pounds. Cant find one that will go that low, lowest is 120 inch pounds. what did you all do? Also why not red threadlock instead of blue with these bolts hardly tightened at all?
had the same problem went to sears and bought a new tork wrench that was in inch pounds as they said (that isn't ft lbs BUBBA) LMAO
Old Jul 26, 2009 | 07:00 PM
  #22
Miami_Son's Avatar
Miami_Son
Originally Posted by dhvaughan
i think any threadlocker is ok.
Not if you ever need to take things apart again. Red requires heat to disassemble. There are very few places it is used, mostly on fasteners subjected to high stress or that should they loosen could cause catastrophic failure and/or injury and generally on bolts 3/8" or larger. Blue is fine for something like this.
Old Jul 26, 2009 | 07:07 PM
  #23
2damnyankee
Originally Posted by onegoodmason
Nice clean up Snook .
Install a filter between the PCV and the intake , or , it will be dirty again in no time . A leaky plenum gasket isn't the only thing that contaminates the kegger .
Cutting the rail is very time consuming , but if you look at how the injecter sits , there is room for improvement there via a dremmel tool . Makes for a better spray pattern in the combustion chamber . I did it on my jeep which works fantastic . And get new o-rings for the injecters too .
here's a reference pic
onegoodmason is that just a paper element fuel filter?
that is a great idea.
Old Jul 26, 2009 | 07:48 PM
  #24
onegoodmason's Avatar
onegoodmason
Thanks , I came up with it after I installed a 01 5.2 in my 95 Grand Cherokee . I so had everything cleaned to perfection ....almost . When I did the down the TB glance a month later during an inspection , I noticed a bunch of junk coming from the PCV line . I replaced the PCV with a mopar part also , it functioned properly . The residue was from the blow-by . I installed a cleanable gas filter with a glass shell to I could moniter it . most any fuel filtr should work fine . I rinse it every 3-5000K when I change the oil . My plenum remains clean , not spotless , but clean .
I think it was on some older cars , but it just made sense to filter the vacumn in this case .
Snook , your really gonna need that torque wrench for inch pds for both the plenum and intake install if I remember correctly
