Front and rear seal leaks
Old Jul 27, 2009 | 06:20 PM
Pyromanaron's Avatar
Pyromanaron
Default Front and rear seal leaks
My rear main and front seal on the engine are slowly leaking. Is it worth the time and effort to replace them? If so, I plan on replacing the oil pump while I'm in there. Should I go with stock or high volume?
Old Jul 27, 2009 | 06:31 PM
dhvaughan's Avatar
dhvaughan
i don't know that its worth doing those as a standalone job. the rear main is not too bad, although you do have to remove starter, cover, pan, oil pump, and loosen the crank. the front seal is in the timing cover, so you have to remove water pump and strip the whole front and top of the motor.
i did both of my seals when i had water pump failure. otherwise, i wouldn't have done it.
general preference is to replace with standard pump, as high volume can pump up more oil than can drain down and cycle around.
Old Jul 27, 2009 | 09:54 PM
360mag45's Avatar
360mag45
HELLYEAH get it fix. i have not had time to replace mine yet and im goin throw about 2 quarts of oil a week and on top of that you lose oil pressure and will have to run heavy oil like 20w 50. oo and your truck well be smokeing alll the time form the oil driping down on exhaust pips.
Old Jul 27, 2009 | 10:21 PM
wjxavier's Avatar
wjxavier
holy f*ck...lol. i'd suggest making some time lol
Old Jul 27, 2009 | 10:26 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by 360mag45
im goin throw about 2 quarts of oil a week.
that's not a leak, that's a hole in the motor. lol.
Old Jul 27, 2009 | 11:24 PM
Ram15002ndGen's Avatar
Ram15002ndGen
We got us a gusher!
Old Jul 28, 2009 | 11:06 AM
360mag45's Avatar
360mag45
yeah i know fixin it soon gonna take a hole weekend and just tune everything and get her running good agin **** load of new **** lol
