39lb injectors?
Old Jul 30, 2009 | 01:58 PM
MikeRWK's Avatar
MikeRWK
Default 39lb injectors?
i have some 39lb injectors from a ford thunderbird supercoupe (supercharged). i was wondering would it hurt to put them in my truck since its not really modded, i figure they might poor in too much fuel or would they be ok? if it wont hurt i'll put them in cause i also have the supercharger and was thinking of puting it on.
Old Jul 30, 2009 | 02:37 PM
BlueBeast2's Avatar
BlueBeast2
Way to much for a stock engine. Even on my modded engine (more then what my sig pic says) I'll be going with FMS 24's. I asked hemifever about 30's cause I had a set and he said no they were too big. Now after a SC install they might work but not now
Old Jul 30, 2009 | 05:11 PM
jasonw's Avatar
jasonw
Site Moderator
+1. 39s are way to much!
The stockers on a 1995 5.2L V8 are 18.2 lb/hr. 39 would be more than double that.
Old Jul 30, 2009 | 05:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
NO BALLZ. Go 4 it!
Old Jul 30, 2009 | 05:30 PM
Silver_Dodge's Avatar
Silver_Dodge
To bad your PCM won't have a clue what to do with them. You should use them as windshield wiper fluid jets instead, probably be a better use.
Old Jul 30, 2009 | 05:35 PM
MikeRWK's Avatar
MikeRWK
its really a shame because they're a direct fit.
Old Jul 30, 2009 | 08:07 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
They'd probably cut through the glass and continue through the top of the truck!
Old Jul 30, 2009 | 10:15 PM
MikeRWK's Avatar
MikeRWK
ok i made a mistake they are 30s, if i added the supercharger would the stock pcm even run these at all?
Old Jul 30, 2009 | 10:56 PM
BlueBeast2's Avatar
BlueBeast2
Still would need tuned
Old Jul 31, 2009 | 07:15 AM
RM_Indy's Avatar
RM_Indy
39lb, put them on ebay cause they are no use to you what so ever.
Stock 5.2 with boost and a real tune with an SCT 24lb will be plenty.
