best place to run wires through the firewall
Old Jul 30, 2009 | 02:39 PM
Scottmilkeway's Avatar
Scottmilkeway
Default best place to run wires through the firewall
hey guys i just picked up some LED GLOZ from my local advanced auto for the footwells in my truck, they need a 12v source for a fact, so anyone have a clue where i could run these wire through the firewall at to get to the battery?
-thanks in advance, Scott
Old Jul 30, 2009 | 02:49 PM
DODGEPWR's Avatar
DODGEPWR
Well, if you dont use your power outlet for anything. I guess you could cut the wires for that and use that source..
I did that in my old ride.. Never used the power outlet in it. So i clipped the wires and used them for somthing else. What are you doing? Putting lights in the floorboards? or what? Thats alittle ricey IMO. But it is your truck.
Ive been useing my power outlet in my truck for a spot light. So im not going to clip my wires for anything.
EDIT: Just make sure you unhook your batt first...Obviously.
Old Jul 30, 2009 | 03:04 PM
Laramie1997's Avatar
Laramie1997
On the Driver's side, under the dash, there is a little rubber grommet that you can drill a hole through. That will give you access to the battery. It's the one that I used to run all my power wires for the amp.
Old Jul 30, 2009 | 03:10 PM
Sheriff420's Avatar
Sheriff420
i used an empty fuse spot on the dash fuse panel for my reverse lights, doing that makes it where they can't have power with the key off.
as far as going through the fire wall, look up and to the left of the brake pedal, on the firewall you will see a rubber plug that you can pull off and pop a hole through. if you don't make the hole too big then it will be water proof because the rubber will squeeze the wire. i have my off road lights and my amp wire run through that plug.
Scottmilkeway
yeah basically floorboard lights, its a little ricey, kinda thought the same thing when i was posting it but whatever, but yeah i might use the power outlet in the future so im gonna leave that and use laramie1997's idea
now you say just drill a hole in the grommet itself? and wheres the grommet located? could you possibly post a pic or something?
Old Jul 30, 2009 | 03:12 PM
Scottmilkeway
thanks sheriff, thats probably what im gonna do
Old Jul 30, 2009 | 03:20 PM
Sheriff420's Avatar
Sheriff420
pull the grommet out before you try to put a hole in it, it'll make it a lot easier because thats some pretty thick rubber and getting a drill up there would be a pain.
Old Jul 30, 2009 | 03:21 PM
Scottmilkeway
thanks will do
Old Jul 30, 2009 | 03:29 PM
Eddielx's Avatar
Eddielx
I drilled a hole in the firewall then I used a rubber grommet.
http://www.jegs.com/i/JEGS/555/10365/10002/-1
Old Jul 30, 2009 | 03:31 PM
Sheriff420's Avatar
Sheriff420
that would work too but the factory rubber grommet is in a good location and it just pops into the hole in the firewall.
