360 idling up when you put it in gear
on
take your iac off and clean the pintle and the hole on the throttle body that it blocks off with carb cleaner then dry and reinstall. don't twist/push/pull or try to bend the pintle, if you do then it'll break. if that doesn't do it then grab a haynes manual and run through the tests for the iac.
