My new pain in the neck (cab lights)
Old Aug 8, 2009 | 04:28 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Default My new pain in the neck (cab lights)
So I got my cab lights on. I used the crimp conecters on the ground and power wire. For the last light I used but splices. When I flipped the switch the light with the but splices came on. I got the crimp things to click down into place. Any ideas? I was thinking just to but splice them together.
Old Aug 8, 2009 | 04:38 AM
speeddemon31176's Avatar
speeddemon31176
check your pm.
Old Aug 8, 2009 | 04:41 AM
speeddemon31176
Never use those splice connectors that are blue in color with the metal tab that slices into the wiring to make a connection. I have seen them be the cause of many a car fire. Use good quality butt connectors and preferably ones that have the shrink tubing on the ends so that you can gain one extra area of security in a good quality connection as well as some sort of waterproofing in order to resist corrosion.
dodge15004x45.9
Check yrs!
Old Aug 8, 2009 | 04:45 AM
speeddemon31176
Just do what I sent you in this last pm and you will be golden.
Old Aug 8, 2009 | 04:48 AM
dodge15004x45.9
Check pm agin.
Old Aug 8, 2009 | 10:44 AM
dakotas ram's Avatar
dakotas ram
use solder and shrink tubing
Old Aug 8, 2009 | 11:08 AM
95MaroonMonster's Avatar
95MaroonMonster
thats the correct way....also waayy too time consuming in my mind
chris101's Avatar
chris101
I think those connectors are junk too, but I have never seen them start a car fire. Fuses are your friend.
Old Aug 8, 2009 | 12:41 PM
Sheriff420's Avatar
Sheriff420
soldering isn't too time consuming if you have a 100 watt soldering gun.
