Bump Stops
Old Aug 9, 2009 | 02:18 PM
JohnnyRebs360's Avatar
JohnnyRebs360
Default Bump Stops
I have a 3" lift on the front of my truck has anybody know what should I do about getting new bump stops?
Old Aug 9, 2009 | 03:03 PM
dakotas ram's Avatar
dakotas ram
youll prob never even hit them....only time ive heard of messing with bumpstops is for lowering
Old Aug 9, 2009 | 04:30 PM
Sheriff420's Avatar
Sheriff420
they keep the axle from hitting the frame, you shouldn't need to mess with them unless they are damaged.
Old Aug 9, 2009 | 05:48 PM
JohnnyRebs360
But shouldn't I consider getting longer stops since I have a 3" lift, Daystar has a 5 1/2" bump stop. Stock size is 2-1/4" to 2-1/2". I don't think I want to compress the shocks or decompress the coil to much.
I know it would only happen if I jumped the truck Duke style.
Old Aug 9, 2009 | 06:10 PM
chris101's Avatar
chris101
if you compress your suspension that much, You either need new suspension parts or you have done something REALLY wrong adn it wont matter much. i wouldnt worry about them.
Old Aug 9, 2009 | 08:30 PM
speeddemon31176's Avatar
speeddemon31176
You do not need new bump stops. The only way you would need them is if you were running the truck prerunner style and I don't forsee that in your near future.lol
Old Aug 10, 2009 | 03:09 PM
Aubrey's Avatar
Aubrey
I suppose the only real reason why you'd need them is to prevent from damaging your springs. You shouldn't have a problem in the front at all. The rears you won't touch unless you had weight in the back and hit it pretty hard. I did not get longer ones for mine and haven't had an issue (knock on wood).
Old Aug 10, 2009 | 03:23 PM
95MaroonMonster's Avatar
95MaroonMonster
with my 2 inch lift, i never hit them
