still runs like s*#% ,what else could it be?
Now you have blue smoke too? That could be the plenum. But you shouldn't be sputtering with a plenum leak. Smoke and knocking yes.
I think you've got a couple of problems and unfortunately none are cheap fixes. Before you do anything, you might start looking at the rest of the truck (suspension, tranny, steering, etc) and see if there are other issues you'll need to take care of. Then add up the cost of fixing all that. Then decide if it is worth putting that kind of money into the truck or putting that money towards another one.
just pulled the fuel pump off looked it over everything checks out fine had a little gunk in the filter/screen, nothing that looked to bad, its just a little blue smoke when you rev it up real fast but no knocking, you can smell exguast fumes real bad, specially when its sputtering, i looked at the cat it has little weld spots all over the side of it, like someone had already gutted it, i live in the stix, lagrande OR. so im sure they did, so those new sensors i put on it was just me pissin in the wind! if you can come up with something from this let me know, i appreciate all the help.
my cat has about 15 or so little weld spots all over it, and smellss like fuel real bad, and sounds hollow if you tap on it wit something,thats why i think its already gutted, sounds like it is too. ive only had the pickup for about a month, so i dont know whats been done and what hasnt? i dont have to restart mine just floor it and it will clear out for a few minutes then it wants to do it again, or first thing in the morning it will as i pull away from the house. one of you ram heads gotta know whats going on come on fellas!!! its progressively getting worse.
It sounds like it is also running rich.
I don't know that a fuel pump failure is typically on the gunked up side. It seems like most failures are on the electrical side of the pump and requires replacing the whole thing.
It sputtering and cutting out could be from a too rich condition or the pump cutting off or both. You flooring it and 'clearing' it means you're bringing in more air and pushing more volume. It's not fixing anything.
i did a pressure test when it was sputtering and dieing out and it went from 45lbs to about 43lbs fuel pressure, so i dont think its the pump? would a dirty intake manifold make it run that bad and just at random times or would it be more of a constant thing? ive read on here that some people say that the front o2 sensor cause it to do that, then others say it wont? im wondering if that high voltage codes that its giving is the problem codes are 132 and 138.
