a 3/4 1/2 ton
Old Aug 11, 2009 | 11:23 PM
360mag45's Avatar
360mag45
Default a 3/4 1/2 ton
alright i got a 1500 with a 3" lift just blocks and spacers. so i want to put 3/4 ton spring packs and coils on my truck will everything fit (it should be about the same just stiffer) how much more lift. can i expect like an added 1" or 2" and will i need new shocks to
Old Aug 11, 2009 | 11:27 PM
Laramie1997's Avatar
Laramie1997
Adding some punctuation and grammar might help the cause....
Old Aug 11, 2009 | 11:32 PM
95MaroonMonster's Avatar
95MaroonMonster
you'll run into the problem of the half ton using 2.5 inch wide springs, and 3/4 tons using 3 inch springs, other than that, it will be a pain in the *** swap
360mag45's Avatar
360mag45
wow i can't type to night sorry
Old Aug 11, 2009 | 11:37 PM
360mag45's Avatar
360mag45
ooo i didn't thinck it would be to hard mybe i well just replace the coils and add a helper spring in the rear
Old Aug 11, 2009 | 11:45 PM
95MaroonMonster
the front will be easy, the rear idk, the difference in spring width means new shackles and hangers, and i think they are riveted on, but it would be a badass swap anyway
Old Aug 11, 2009 | 11:50 PM
360mag45's Avatar
360mag45
well if im lucky there just bolted on if there rivited on im screwed casue my plan was to go to the junk yard and pull the parts an all and make it look oem
Old Aug 12, 2009 | 08:29 PM
olyelr's Avatar
olyelr
Dont bother with swaping rear spring hangers just to use the 3/4 ton leafs... just install and add-a-leaf.
The front is just a simple swap. The 3/4 ton coils will net somewhere around 2" of lift if they are from a gasser and more like 3" if they are from a deisel or v10. I gained nearly 3 1/2" with my coils.
The issue you may run into though is you are going to gain too much lift for the stock front components (control arms, track bar/pitman arm etc.). What size spacers do you have now? The stock components are really only good for about 3 extra inches total, which you will be pushing 5" or more if you install 3/4 ton springs under those spacers.
Or do you plan on removing the spacers?
Old Aug 12, 2009 | 10:26 PM
360mag45's Avatar
360mag45
i have a 3" spacer up front and new shocks from procomp its i belive 2 3/4"lift in the rear and 3" up front and that was all in the kit so maybe those shockes well be big enoff to handle the extra hight idk
Old Aug 13, 2009 | 07:55 PM
olyelr's Avatar
olyelr
As long as you are planning to take out the spacers you will be fine.
