Which Plenum Gasket Should I Get?
Old Aug 15, 2009 | 08:16 PM
Ram_Me's Avatar
Ram_Me
Originally Posted by notanexit7
what's the timetable for the stock gasket blowing out? i had my engine rebuilt and the guy put a new gasket on and that was 10k miles ago.
I'm not sure what the timetable is, but I'm sure someone else on here knows. Do you know if he put an OEM gasket on or an aftermarket kind? Also, there is a way to tell if oil is in your intake, all you do is take off your air filter housing, and look down the bores of your throttle body. If you see oil pooling inside, you have a leak. You will need a flashlight.
Old Aug 15, 2009 | 09:47 PM
Hahns5.2's Avatar
Hahns5.2
My favorite plenum gasket fix..
Old Aug 15, 2009 | 09:49 PM
Ram15002ndGen's Avatar
Ram15002ndGen
That is a beautiful device, but unfortunately it's also very expensive.
Old Aug 15, 2009 | 10:12 PM
Trey318's Avatar
Trey318
Haha I got one of those sitting in my closet waiting for the 408
Old Aug 15, 2009 | 10:29 PM
Ram_Me's Avatar
Ram_Me
I want one. Now. Is that the one from hughes engines? That's like $600?
Old Aug 15, 2009 | 11:31 PM
99_ramsport's Avatar
99_ramsport
So i'm about to purchase the Hughes kit. Are the guys saying "not" to use that gasket and use the felpro gasket or is the hughes gasket good also?
Old Aug 15, 2009 | 11:51 PM
Ram15002ndGen
The opinions around here are that the gaskets they come with are not as good as the felpro.
Old Aug 16, 2009 | 01:23 AM
mcss8541's Avatar
mcss8541
I redid my plenum about a year ago and got the $24 kit from O' Reilly's I didn't know about the bolts needing to be replaced though. What's the cost of this Hughes kit and where can I get one. Also if I think it's the gasket but there's not much to hardly any oil down in the bottom pan should I redo it anyway. ( Look at my post called " Low Compression in cyclinder #6 ") and see what you think.
Old Aug 16, 2009 | 11:20 AM
Ram15002ndGen
Look up the posts by JasonW and get his take on it. He says he didn't have hardly any oil on his until they took it apart and then he realized how bad it was. That may give you some indication of which way to go.
Old Aug 16, 2009 | 12:27 PM
BaiN631's Avatar
BaiN631
MOre info on this?
