Which Plenum Gasket Should I Get?
Old Aug 16, 2009 | 12:35 PM
  #21
onegoodmason's Avatar
onegoodmason
I don't think theres a timetable one can follow for the plenum . If you've seen what DC used , it's a thin metal gasket , eventually , it bound to fail and leak by design .
If you notice , the plenum is tilted down towards the rear . Back the truck up a steep grade , now , if you have pooling oil , its coming forwards , look down the TB with a flashlight . Don't be fooled by the crap that comes through the PCV (blow-by), that should appear more like a residue .
Best thing , do the test . Mine failed (one my 5.2 jeep)when I first did a plenum gasket test . I replaced it with stock , not knowing better . It failed again in 3 months . I replaced the engine and redid the plenum with a fel-pro , stock plate and anaerobic gasket maker (made for mating 2 different metals), it's been over a yr , it was tested a month ago with perfect results .
My 200 K Ram is still original AFIK and can tell , no major oil consuption , no pooling in the plenum and no ping . I never felt the need to even test it yet . When it does need redoing , I'll go the same way again , cheap .
Old Aug 16, 2009 | 02:21 PM
  #22
mcss8541's Avatar
mcss8541
Other than checking down the TB blades what's the other test????
Old Aug 16, 2009 | 02:23 PM
  #23
mcss8541's Avatar
mcss8541
Originally Posted by Ram15002ndGen
Look up the posts by JasonW and get his take on it. He says he didn't have hardly any oil on his until they took it apart and then he realized how bad it was. That may give you some indication of which way to go.
OK will do but where do I get these Felpro gaskets and Hughes kits etc.
Old Aug 16, 2009 | 02:51 PM
  #24
onegoodmason
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Aug 16, 2009 | 10:22 PM
  #25
99_ramsport's Avatar
99_ramsport
i'm going to get the hughes kit for my 99 5.9 but can't find the felpro gasket.... can someone post a part#
Old Aug 16, 2009 | 11:19 PM
  #26
Ram15002ndGen's Avatar
Ram15002ndGen
The best suggestion I can give you is to use the SEARCH feature to look up the posts relating to the plenum gasket. There are a lot of knowledgeable guys around here but I'm sure they don't want to have to repeat themselves. The SEARCH is your friend, and it's free, used it! Read through the posts and make up your own mind as to what works best for you, and many of these posts will have links in them.
Old Aug 17, 2009 | 10:29 AM
  #27
sungod's Avatar
sungod
I wouldn't waste time looking for the felpro gasket. The gasket that is shipped with the pan replacements is more than adequate. It is only someone’s opinion that the felpro is better. There is no verifiable proof that either is superior. There are no reports of either failing. The problem was the steel pan, not the gasket.
Old Aug 17, 2009 | 11:08 AM
  #28
Dr Donut's Avatar
Dr Donut
you can get the felpro gasket kit at autozone for 25
Old Aug 17, 2009 | 08:56 PM
  #29
olyelr's Avatar
olyelr
Why would a well known company such as Hughes offer such a good product and offer a junk gasket with it? And if they actually were having issues with the gaskets (which Im sure they would hear about it), I would think they would have changed them years ago. I just used what they sold me (except for the first warped plate).
Old Aug 18, 2009 | 05:38 PM
  #30
frankie27's Avatar
frankie27
when you guys changed your plenum was your pickup, starting to sputter and hesitate, backfire?
