mud tires
Old Aug 13, 2009 | 08:40 PM
mint5jf's Avatar
mint5jf
Default mud tires
I got new dynapro mt by hankook and after I got them put on my truck it sways like I have 2 really low tires in back. Is it because they are very thick rubber or mud tires . I'm getting them replaced Saturday and I hope the problem goes away. The swaying happens at any speed but obvisously worse the faster you go.
Old Aug 13, 2009 | 08:57 PM
dodge15004x45.9's Avatar
dodge15004x45.9
What?
Old Aug 13, 2009 | 09:10 PM
'95Dakota's Avatar
'95Dakota
the back end feels like it moves back and forth?
Pump them b!tches up! lol
Old Aug 13, 2009 | 09:45 PM
mint5jf's Avatar
mint5jf
they are at max pressure.
Old Aug 13, 2009 | 10:08 PM
lastrights's Avatar
lastrights
hmmm i dont have any probs with my M/T , did the put on the lug nuts right??
Old Aug 13, 2009 | 10:11 PM
dodge15004x45.9
You should not be running them at max psi.
Old Aug 13, 2009 | 10:16 PM
Mowhawk's Avatar
Mowhawk
Yeah you shouldtn be doing that. Mudd tires are like that, your going to be gripping and following the road however its slanted. I sway from side to side often, uneaven roads.
Old Aug 13, 2009 | 10:31 PM
dodge15004x45.9
I guess you do 4.10's and yr tires which should be mine!!!
Old Aug 13, 2009 | 10:57 PM
mint5jf's Avatar
mint5jf
i know it sounds retarded and i expect to be laughed at but its wierd that as soon as i had them put on that it started happening. i didnt know anything like that was possible. i had stock 16 inch rims and with some old 265 mastercraft at's and it did not sway like that then i switched to 17 inch rims and 285 hankook mt's and now it sways pretty bad
idk im confused now to what the prblem is.
Old Aug 13, 2009 | 11:18 PM
xskylinedx's Avatar
xskylinedx
maybe hankook doesn't build their mt's with a strong sidewall. I'm guessing that the load
rating of the tire might be in the passenger range rather than the light truck. just a guess
