DIY idle air control motor
Old Aug 16, 2009 | 06:36 PM
jimp1114's Avatar
jimp1114
Default DIY idle air control motor
Any body got a good link for this. My Dakota is idleing and stalls out in reverse. I'm assuming that this is the cause. Much help appreciated.
Old Aug 16, 2009 | 06:51 PM
dakotas ram's Avatar
dakotas ram
it just bolts to the back of the throttle body, th ered is it and the blue is where it goes, just on the outside of the tb
Old Aug 16, 2009 | 10:50 PM
Ram15002ndGen's Avatar
Ram15002ndGen
So you want a DIY, ok here goes.
1-Open hood of vehicle.
2-Locate IAC.
3-Go to local auto parts and buy a new IAC.
4-Return home
5-Take out old IAC.
6-Install new IAC.
7-Have a brewsky.
Neither myself nor Dodgeforum will be held liable for any fouled up results leading from following my FREE DIY IAC replacement guide. If you screw this up, it's your bad.
Old Aug 17, 2009 | 12:34 AM
2001Ram's Avatar
2001Ram
Always try cleaning it first, usually when they get dirty they dont work.
Spay it with some carb cleaner.
