254HR Cam
Old Aug 17, 2009 | 03:04 PM
BigRedRam95's Avatar
BigRedRam95
Default 254HR Cam
What do you guys thank this cam will do to my MPG I am also putting 4.10 gears in at the same time. http://www.compperformancegroupstore...CAMRFHRCC92-02
Old Aug 17, 2009 | 03:18 PM
Gav1n8's Avatar
Gav1n8
probly not affect it very much. kinda depends what you drive... interstate? town? either way you probly wont care to much cuz the combination of a new cam and new gears should make u feel warm and fuzzy inside... I want 4.56 gears
Old Aug 17, 2009 | 03:43 PM
BigRedRam95
4.56 were to low to run with my 32s
Old Aug 17, 2009 | 03:51 PM
Dr Donut's Avatar
Dr Donut
let me know how this works for you as I was looking to upgrade mine in the near future
Old Aug 17, 2009 | 04:06 PM
BigRedRam95
I need to come up with the money to get the cam and new springs I have the set of gears coming in the mail but dont know how long it will take to get the cam
Old Aug 17, 2009 | 04:08 PM
Dr Donut's Avatar
Dr Donut
You are correct sir!
Old Aug 17, 2009 | 08:31 PM
aim4squirrels's Avatar
aim4squirrels
More Performance = worse MPGs.
Old Aug 17, 2009 | 09:19 PM
BigRedRam95
How much worse most of my drive time is spent at 55 or under
Old Aug 18, 2009 | 10:03 AM
lastrights's Avatar
lastrights
just baby it , at least you will have the power when you need it /want it
Old Aug 18, 2009 | 05:29 PM
aim4squirrels
Are you running oversized tires? If stock, the new gears your RPM's will run higher and burn a bit more gas, if the tires are bigger, it might help a bit. The cam will cost you MPG's regardless of the speed. If Chrysler could have designed a cam that would give you more power and better MPG's, it would be in your engine right now.
