Upgraded Front Axle Shafts
Old Aug 17, 2009 | 03:27 PM
Aubrey's Avatar
Aubrey
Default Upgraded Front Axle Shafts
Has anyone seen upgraded front axle shafts for the 1500? I've found stock replacement and Alloy axles for the rear. I've only been able to find stock replacements for the front. I see universal ones that have to be cut down. I'm not looking for that though.
I'm getting a clicking from the front when I engage the axle. I also need to replace the bearing. Since I'm pulling it apart to do the bearing and find out where the clicking is coming from, I thought I'd start looking at axle prices in case I have to replace one. I just can't find an upgraded front axle though.
thanks
Old Aug 18, 2009 | 01:42 AM
Kraiger's Avatar
Kraiger
Call Moser. Yes they are pricey but you can get chromoly. They you will have no problem.
Old Aug 18, 2009 | 03:07 PM
Aubrey's Avatar
Aubrey
Moser doesn't have them for our trucks.
Old Aug 20, 2009 | 02:06 AM
Kraiger's Avatar
Kraiger
well they say they can make anything.. So they can.. I was looking into my front dana 44 when i was building my truck and moser said they would build me axles for it.. I went with a 60 instead but i have moser axles all the was through that Dodge 60. Even the passeger side is now a solid shaft not 2. If moser still wont, look up EMS Offroad. They used to carry moser axles but have stoped and went with another brand but still are chromemoly.
Old Aug 20, 2009 | 10:23 AM
Aubrey's Avatar
Aubrey
Ah, yeah, I'm not looking for a CAD delete or a completely custom shaft. I'm looking for one that someone makes on a regular basis for stock replacement. I've found some (not chrome moly) ones from Genuine Gear, Motive Gear, Alloy, and Yukon for the rear. The only fronts I've been able to find are just stock Dana pieces. Which have certainly served me well. Just thought I'd upgrade them if I had them out. Not sure sure I'll need them yet. Just doing some research before I pull it apart to replace the unit bearing.
Thanks for the info though.
Old Aug 20, 2009 | 11:40 AM
Twisted Metal's Avatar
Twisted Metal
Check with Strange, or CW. IIRC Strange at one time offered axles for the 44 and 60 that were upgrades over stock.
Old Aug 20, 2009 | 02:06 PM
SpcD1500's Avatar
SpcD1500
i dont think anyone makes the outer stub shaft cause of the way it turns from splines to threads.
Old Aug 20, 2009 | 06:40 PM
Aubrey's Avatar
Aubrey
Here's what I was able to find.
Rear:
4WheelParts, Genuine Gear, $105
AccuAutoParts, Motive Gear, $75
AccuAutoParts, Yukon Gear, $129
DrivetrainOutlet, Alloy USA, $85
Randy's, Yukon, $133
Front:
AccuAutoParts, Dana, Left Assembly 232, Center 75, Right Assembly 280
Quad4x4, Dana, Left Assembly 350, Center 100, Right Assembly 405
Quad4x5, Dana, Individual Pieces 120, 195, 100, 250, 120
Old Aug 20, 2009 | 09:55 PM
dhvaughan's Avatar
dhvaughan
check here.
http://www.riversidegear.com/categor...e-4-x-4-parts/
looks like each piece is about $150.
Old Aug 20, 2009 | 11:48 PM
Kraiger's Avatar
Kraiger
Do you have 4w ABS? Im not sure on the outer shafts upgrade. All the trucks i have done i have but a manual hub conversion on with the CAD delete axle...I have used Dynatrac and EMS off road...EMS is the cheapest but i like the dynatrac on my truck...when you convert you get new outer shafts. Price is around 1000 for EMS and Dynatrac is 1700-2000 depends where you get it from.
