question about suspension/steering
Old Aug 17, 2009 | 04:59 PM
wjxavier's Avatar
wjxavier
Default question about suspension/steering
ok, i was under my truck yesterday replacing my cat and have been noticing a few things that look like they need replacing. i know i need new u-joints, so when i was looking at those, i realized that my left lower ball joint looked a little rusty and dry and the little rubber boot thing kinda just fell off when i tugged on it. do you think it needs replacing? or can i just wiggle the knuckle back and forth to see if it needs it? also, it says in the haynes manual to take the knuckle and ball joint to a shop to have it pressed in. is that required or can i pound it in?
also, on the stabalizer bar, the connection on the drivers side(where it connects to that bracket thing by the coil spring) its cocked pretty far to the right...is this normal? or is it screwed up and needs replacing? just curious.
also lots of squeaks and stuff when i'm turning. should i just lube everything that has a fitting? lol i dont know when the last time was it had a lube job.
Old Aug 17, 2009 | 06:32 PM
Aubrey's Avatar
Aubrey
Yes, it needs replacing if the boot is falling off. Seeing if you can wiggle it will tell you if you can wait a bit to do it or if you shouldn't be on the road at all.
Never heard of taking it to be pressed. They make ball joint tools you can buy or rent.
That's somewhat normal but the ***** could be shot. May need to end links.
Lube it. Do it. Lube it good.
Old Aug 17, 2009 | 07:08 PM
wjxavier's Avatar
wjxavier
ok...thanks alot for the advice
Old Aug 17, 2009 | 08:51 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Didn't your mother ever teach you not to tug on things cause they may fall off?
Old Aug 17, 2009 | 09:02 PM
olyelr's Avatar
olyelr
The squeaking you are hearing is more than likely a failing ball joint.
Pressing them out and back in is the easiest route, but nicely beating them in is somewhat feasable too (I did a few that way on my truck). I rented the press from auto zone and it worked wonderful (and its free as long as you bring it back).
Im not sure on other trucks, but on my dana 44 the ball joints actually press into the axle portion of the "C", not the spindle.
