Question about tranny and engine
Old Aug 18, 2009 | 10:19 AM
99ramdodge's Avatar
99ramdodge
Default Question about tranny and engine
Well my first question is about my engine it has 166k miles on it and it starts right up every time has good power doesnt leak oil, but it burns like 2 quarts every 60 miles, is it about time to get a new engine or this one rebuilt? My other question is about my tranny it has 166k miles on it and its started to shift late or a lil hard, would that be the stall converter causing that or does that need rebuilt too.
thanks
Old Aug 18, 2009 | 12:04 PM
Aubrey's Avatar
Aubrey
Oil leak - possible plenum leak
Tranny shifts - possible bad fluid, need band adjustment
Old Aug 18, 2009 | 03:04 PM
gobbell1's Avatar
gobbell1
Concerning your tranny, see my thread here...https://dodgeforum.com/forum/2nd-gen...y-rebuild.html
It will walk you thru the steps...
Old Aug 18, 2009 | 04:45 PM
jasonw's Avatar
jasonw
Site Moderator
The eating oil is probably a plenum leak, like Aubrey stated. Doesn't require a rebuild, just a Hughes plenum plate and a Felpro gasket. Good for life.
Or the Hughes FI Intake. Good for life that way to, and more power/MPGs, but much more expensive.
Old Aug 19, 2009 | 01:21 PM
dblj16380's Avatar
dblj16380
Beware also though because if you are burning oil then it could be blown head gaskets too! Make sure to go through the proper diagnosis to figure out exactly whats wrong before you tear into things (vacuum test for plenum and compression test for heads).
Good Luck!
