Lift question for the guys...
That is one way to go, but you can get air shocks cheaper than that still if you are on a real tight budget. There is no need for a controller. They have a nipple that you locate somewhere and you get a compressor and fill them up with air. When you're done you bleed out the air. With air shocks though you do have to leave a little air in them for a proper ride. Carry a little 12 volt compressor and your good to go.
air shocks are simple and affordable, but i have one concern. when you use air shocks to support an abnormally heavy load, much of the weight gets supported by the shock mounts instead of the springs. I understand that shocks see an incredible amount of force while driving, i just dont like the weight being supported on brackets that werent meant to be load bearing.
That being said. i had an 89 s10 that i lowered and needed to put air shocks in to support my 800lbs quad and it did fine for the couple of years I owned it.
I had an old Pontiac wagon that had very soft springs. It was made to have more of a comfortable ride than to carry big loads. Since that's all I had back then before I got my truck, I put air shocks on it and it would carry anything I needed. Once time I loaded it up with I don't remember how many sacks of cement (100lb each) and it took it with no problem. The air shocks can carry a lot of weight. One thing though, you never want to have them fully aired and with no weight. First off your a$$ will be in the air, and second it will be a teeth jarring ride. When empty you have to keep them at half or less or you will hate the ride.
or another easy alternative is some overloads like i have, the trucks ride didn't change much (i have an Add a Leaf anyway, so shes pretty stiff as is)
but they cost less than 200, and once i adjusted the tension on them (you adjust them when you install, more tension = stiffer ride, and less tension = smoother ride, and for what your doing, you wouldn't need too much
plus with them, install and forget, no need to air up or down
i ordered the 2500 lb ones from JCWhitney, the work great for my application, and would work stellar for what your pulling
So been doing some researching and also asked someone on here and he suggested some "timbrens" Any opinions on them? The few reviews on here were ok but would like to get a better answer than "OK"
